2007 LS460L and the Venerable Ipod
If all goes well, I should be the proud owner tomorrow of a 2007 LS460L, Silver/Black, pretty muched decked out in everything except Sport and Exec packages. Now, what options do I have for hooking up my Ipod, controlling it with the car controls, and possibly even viewing the music/playlists on the Nav screen? I've skimmed a lot of posts, but I'm still frightfully unclear about VAIS, Prestigious Society, etc and what exactly they all do and how much brain damage they are to install.
Also, any other technical upgrades that make sense?
Thanks
Thanks
if you want ipod integration and display on the nav, full integration and use of radio / steering controls, vaistech is your answer.
if you want to be able to use the nav when driving (and access phone book, song list, etc...), then the ps override will do that
Well, just got home with it. 42k miles, but there is not one imperfection in the paint. Amazing car. Only thing better would be a 2010
Okay, additional questions on the VAIS:
1. Does the Vais Ipod integration allow XM functionality? I know the Lexus Ipod interface kit does not, as both use the same connection. I thought I read here that the Ipod integration on the Vais uses a different connection.
2. Is there any hardware/switch/etc that has to be out and about somewhere versus inside a covered area? I just hate the idea of a switch that has to be flipped everytime I get into the car, or an additional button somewhere on the dash.
3. Is installation easy enough for a mechanically inclined person to perform, or is it better left to the experts?
Thanks!
Thanks!
1. vaistech does not interfere with xm
2. if you talk about vaistech, no switch no nothing, just the ipod cable. if you talk about the override, there will be a switch for you to override the system
3. personally it's very easy for me, i wouldn't say it's very hard for people in general
Okay, almost there. A few last:
1. Which VIAS makes sense if I basically just want Ipod (Iphone 3G) integration. IE, I want to be able to control the Ipod, while driving, through the steering wheel and/or the head unit.
2. I thought there was a thread on installation here, but I can't find it. Any source for installing the VIAS in an LS460L ML?
your choices are sl2i-up and vml. vml can do usb and hdd as well, but more expensive. personally i think sl2i-up is a better choice. you can control using steering wheel and head unit, but access to folder list directly is disabled when driving (unless you get override)
Sorry, as you anwser I keep thinking up new questions. Now that I understand the SL2i-up, it seems like the solution I was looking for, including browsing by artist while driving, which is how I use my Ipod generally.
Now, using the SL2i-up, where and what do you plug the Ipod into? I thought there was not anything else "hanging out" in the car, so does this somehow use the Aux/Power outlets in the armrest? Or do you end up with a new cable somewhere? Or does it replace the Aux in the armrest?
Ahhhh, okay. Where are people finding it's useful to run the cable to? I like the idea of running into the ashtry area, as that has no use for me otherwise, and I need access to my Iphone while driving, sometimes.
I suppose worst case I could run it to the glovebox and get a plain old Ipod and leave it in there.
Will the PS get ride of the "I AGREE" lawyer screen?
I hate having to push the button every time I take off, my tech the only way to get rid of it is to upgrade to the new NAV version and he can bypass it while programming it. The new update will cost $2-300 which I don't think it is worth it.
BTW great info thx guys!
your tech is sort of wrong. the new nav version (since 7.1 i believe) does not have the i agree screen anymore. that's my default. your tech doesn't have to do anything to "bypass" it
Oooooh, it would be great in the armrest. I have never personally cracked any of this stuff open, so pardon the dumb questions. Is the cable long enough after being inserted into the armrest? (I suppose I could just buy a short extension if not. Would there be a gaping hole where the cable was passed through, or do most installers have a way to "refill" the holes?
I'm taking my car to the dealer in the morning for some additional work - can they usually just install the latest Nav version or does it have to be ordered? It would be worth the $200 just to get rid of the "I AGREE" screen. I think we're up to 9.1 if I remember correctly.
The cables supplied with the VAIS unit easily reach the armrest compartment. I should know, I installed mine today
In fact, I put the Vais unit into the armrest compartment along with the iPod, easy access for future firmware updates. Getting things opened up and then closed again was not hard.
Last but not least, the VAIS gets rid of the "I agree" screen after a couple of seconds, so no need for the Nav upgrade, unless you need updated maps.
