Video options for LS460 with ML system
I have a 2007 LS460L with ML and am wondering what my options are for addin tv screens to it. From what I read the system already has a dvd player in the dash. Can I add monitors to it and use it to play dvds? I know there is an overhead option from Lexus and I dont want to even imagine how much that console and needed items cost. I think I want to do headrest monitors but want to know if they can be fed via the dvd changer in the dash.
I'm sure someone else has ran into this and hopefully you can give me some help and guidance.
Has anyone added the OEM overhead unit to their ML system? I've seen it offered without the executive option so it must be able to be added and usually the harness will have the plugs for it so in theory you could just add it but some times you have to buy alot of little add on things that makes the price skyrocket. The list price for the unit is a bit over 1200 and I can get 28% off of that so it would be cheaper than prebuilt headrest monitors
I had asked this question over a year ago after seeing a post from somsone who did put headrest screens in tied to the head ML unit but I could never get him to elaborate or return a PM. I think it would be great to add headrest screens to the ML for those of us who have done the PS modification and can use the DVD while in motion. I suspect the OEM rear unit does not integrate with the head unit due to the moving lockout feature of the ML head unit from the factory.
There was a mention of a custom made wiring harness if I recall his post. Id have to search fro it. Still didnt elaborate or say much about it, so could have been BS.
The rear seat system can display the DVD that's playing in the changer. I don't think the front screen can display an image from the rear seat DVD player, but the rear seat DVD audio can be fed to the ML audio system.
Jim,
What we are trying to figure out is those cars that do not have the rear seat system which is the overhead unit, can we add headrest screens that tie into the front head unit. Youre right in that the ML locks out the video, but thats without the PS mod which does allow for playback while driving. Seems simple to split out the video feed to two screens in the headrests, but I just havent seen anyone do it.
Jim,
So it looks like a video output is available, it's a question of whether the wires are already in place. The connector is L56 on the radio, an 8-pin connector that also provides the video signal to the nav screen.
Pin 5 is NTRO which I am assuming means NTSC REAR OUT, 6 is ground, 7 is shield. I would suspect that this video signal is present regardless of whether the vehicle is in motion or not, since it's intended for rear seat viewing.
It should be pretty easy to hang a video monitor on those pins and see if there is a signal there.
I will be installing a set of vizualogic DVD headrests in my '07 next week. I was more interested in finding a way to put an external video signal into the front screen, but it will be a good time to do some experimenting.
Each screen can select from 4 sources: It's built-in DVD player, the other headrest's DVD player, a front-panel A/V input, or an external source input to the junction box that ties the units together.
I was originally planning on using a WD 'Live' media player for the aux source, but now I might try hooking up the extra video out on the ML system as the aux source.
$300 for the custom headrests?!!!!!!????! Where did you get those? Do they look like the originals? I was going to try and remove the back of my headrests and custom make a backplate for the monitors. I would be very interested to know what the other equipment you have used and how you wired them up.
Thanks
Thanks
I agree there are many standalone options, but I think having the ability to use the front head unit then allows for the wonderful surround sound ML system. Having put in the PS modification, I didnt notice any other outputs, but will be very interested in seeing if its possible. To me that would be the true advantage of having the PS mod for rear seat viewing.
Thanks
Thanks
Thanks
Thanks
