Instructions For The "JMcRaney Wind Noise Fix"
#166
The part is exactly the same, it just has a little fin on it. Nothing was changed for 2016, that part was redesigned with the large scale refresh in 2013.
The wind noise issue that this fix addresses is caused by the way the part is installed in the trim, has nothing to do with the part itself.
jmcraney (11-18-20)
#167
I am very knowledgeable on this subject. Most of the “wind noise“ problems that were related to the trim were gone by the ‘11 models, long before the new trim part was introduced. The wind noise was a major problem in the earlier models. Although many of the cars produced in that period had a wind noise problem, many did not have a wind noise problem. This has been explained extensively in this forum.
#168
Thanks
Glenn
ill57 (12-29-21)
#169
Well, I believe there is a strip on the inside and one on the outside. You didn't indicate which you are referencing. I think, as to noise, the outside one would be more important. I don't believe these parts are expensive or difficult to replace. The fact that the seal is not contacting the glass may indicate a problem with the seal, or in could be the result of the glass not being in the right place. Since you have demonstrated to yourself, using the painter's tape, that there is improvement to be had with a better seal, seems like you would want to do that. I don't recall anyone ever telling us that they needed to replace those parts.
#170
Thanks
Glenn
ES350Bob
ES - 5th Gen (2007-2012)
09-09-06 04:46 AM
