How to reset the memory seats?
Old 12-30-15, 12:02 AM
philnshelb
philnshelb's Avatar
Thumbs up memory seat
Originally Posted by CJITTY
This is crazy!! I mean, this is very valuable info here!! Great post...reminds me of Up..Up..Down..Down
..Left..Right..Left..Right
.B....A...Select...Start lol #olSchoolContra30Lives
I will have to try this tomorrow they have not worked since I disconnected the battery
i too enjoy the up down left right for a little while longer as i will be officially retired this coming July
Old 07-26-17, 12:50 PM
tomkenney
tomkenney's Avatar
Thumbs up
Originally Posted by dealerGM
I have a 2007 LS460L and installed my "prestigious society" nav video override today. I noticed my seat did not go Back into position via memory when I opened my door after my install. At first I thought I burned a fuse and checked them all, not the problem... next I was thinking I needed to reprogram the vehicle's computer after the battery was disconnected for the install...
I came to the CL forums and did a quick search for "memory seat" and quickly found a possible solution. I tried this and WOW! It worked like a dream. Thank you for the information!
memory seats reset.
This is also worked in my sc430 thanks tried everything before I found the right thing!
Old 10-03-18, 11:41 PM
Lxandrxh
Lxandrxh's Avatar
Default Perfect
Originally Posted by hlevin
Check with your dealer on the right procedure, but I believe that what you need to do is move the seat all the way back, then lower the seat back all the way, put the seat back all the way forward, then move the seat all the way forward, then all the way back. It sounds ridiculous, but I had this same problem and that's how the seats reset. I may be a bit off on exactly which order to do things in, hence the "check with dealer" above.
this works a treat, I just did this on my LX470 2005. It appeared to not work, turned the car off got out, got back in turned the ignition on and it worked perfectly 👍
Old 11-01-18, 10:40 PM
SigmaBlue
SigmaBlue's Avatar
Default Reprogramming car seats for 2006 SC430
Thanks again for the advice. This is the third time I had to go to this site for guidance. I have save over $300.00 and it took less than 5 minutes for each repair.
Aus430
02-11-19 01:34 AM
A1cntrler
03-01-16 03:37 PM
Shervin350
09-20-12 01:42 PM
jxd
02-04-11 08:49 PM
dandd2
07-23-05 06:23 PM
Quick Reply: How to reset the memory seats?
