Different rim widths or not?
Has anyone replaced their wheels with aftermarket rim 20"+ with the same width rims front and back. Every example that I have seen on the forum has wider rims in the back. I am thinking that if I wanted a sportier look this would be good but I was thinking the same on front and back would look more even on the car and also it would let me rotate tires later![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Any comments or opinions on this?
I see on the rear wheels. I wouldnt want it to be sunken in. I was thinking the offset would compensate for that but am I wrong. If I need the wider rear rims to fill it in I will though
now of course, you can get the same width wheels and different offsets so both front and rear look better, but with that, you won't be able to rotate the wheels
personally i don't really care much about rotating the wheels. i just change my front tires (pair) and rear tires (pair) separately
