Toyota recalls LS, other models for valve spring replacement
#421
#422
mine is at the dealer now while I am on biz travel...getting an oil change and alignment free due to some new swirls when they ran my car through the terminator wash last time it was there..smh
#423
A question for everyone. How do you get the $500 gift certificate? Does Lexus automatically send you one after the VSR is done? Do you have to have purchased an extended warranty before they send you the gift certificate?
Thanks
Jarm
Thanks
Jarm
#424
Also, per my postings about half way thru all this - there is nothing mechanically being done that would affect idle speed, gas mileage, or the need for an oil or coolant change. Not saying there may at times be a need for some adjustments, but it is unlikely the cause was changing out the valve springs themselves.
#425
If you already have purchased an extended warranty before the work is performed (the definition of how much time "before" is apparently under discussion by Lexus), you will receive the $500 gift certif good for Lexus goods. If you dont have an extended warranty on file, Lexus will extend the "powertrain warranty" to 100,000 miles (no extension of original warranty time though).
In either case, you also receive $1,500 off your next purchase or lease if used within the next 12 months.
For the record, this is all actually being done by "Lexus Financial" the financing arm of Lexus.
#426
It's been about a week since I had the VSR done. This morning while my wife was going out with the LS, outside of the car, I noticed the engine is running much less noisy. Inside, while driving I never noticed. So like most everyone mentioned the engine is quieter after the VSR.
#429
Just brought the LS home from the dealership after the valve springs replacement. The engine runs fine, seems a bit quieter at idle, no acceleration problems (was sort of worried the computer updates might get lost with the battery disconnect). The gas tank was filled. The only odd thing is the computer says 10.9 MPG since last refill. It should read at least 22-24 MPG. Funny, when I got home the wife says your recall letter just came in the mail.
#430
#432
Seems Lexus is working their way from East to West, as I just got my notification today for the vsr. As we have only one Lexus dealership in Hawaii I don't have the choices that you all have on the mainland as to where to get it fixed. To my knowledge their are less than a dozen LS600HLs on the island. I know the mechanics here have no experience with the Hybrid models, so I am really not looking forward to them working on it. I happened to see one of the shops with a Toyota V6 pulled out of the chassis lying on a bench disassembled for problems with the camshaft and valves. The most disturbing thing to see was two mechanics scratching and shaking their heads, then leaving for lunch leaving the whole assembly uncovered. I may have missed some posts, has anyone else with an LS600HL had theirs done? Have you had any problems mechanical or electrical after the fix?
#433
Hawaiian LS600HL
I think you may be a candidate for "fix as fail". Many here have reported high mileage on their LS460's - one up to 130,000 miles without the VS failure. But there have also been several VS failures reported here.
Back in July Lexus published– “Lexus estimates that the likelihood of a customer vehicle experiencing this condition is two-tenths of one percent (0.2 %). Lexus has received no reports of accidents or injuries related to this condition. No vehicles from the current 2010 model year nor 2009 are affected.”
You chances of these "head scratchers" screwing up the VSR job and other more costly things in your Hybrid are probably much higher than 0.2%. Remember that the dealer is not reimbursed for screw-up’s by Lexus.
Of course there is the safety issue and inconvenience of having a road failure. Don’t know – but would the electric drive allow driving to a safe place off highway?
I certainly wouldn’t offer up a $120,000 LS600HL for their training program.
My LS460 is garaged for the New England winter and will have the VSR done in April.
Your mileage may vary.
#434
Just got mine back yesterday from the dealer. It does seem to be a little quieter, before i took it in, it did have some ticking, but i don't hear it near as much now. Fresh tank of gas as well. My advisor said i would get the $500 as well, not sure when that is or how that works, i assume as folks say i will get once paperwork is submitted by dealer to Lexus of America. It's done now, will wait and see how things work out
#435
If the car fails due to an issue with the valve springs after the warranty expires, will Lexus still take care of it?
I haven't read anything about time limits. So does that make it an open-ended thing?
Some people sold their car already and now the car is with the new owner. Which owner will get the $500 gift certificate? If it's the latter, where do they get the newer owner's information from?
