Trunk Adjustment
Is there anyway to adjust the tension level for the trunk? When I open it on a slight incline it will not stay open and starts to fall down. I tried to do a quick search but didn't come up with anything, sorry in advance if I missed it.
Thank you,
Ryan
Thank you,
Ryan
You might need to replace the piston arms that support the trunk. This is normally needed after 7-10 years, so I'm shocked to hear of it happening on such a new vehicle.
Mine is experiencing the same problem. When on a steep hill it opens all the way then starts falling and stops 2/3s the way closed. It makes it a pain to get things out since it will not stay open. Has anyone ever had this problem and fixed it?
