need help on rims asap!
considering no1 helped me out w a similar question/post, i would suggest 2 options. call the manufacturer of the rim and ask, or simply jack up the car and see if it fits. honestly the numbers u posted should fit w/ no problem..im sure i wasnt any help, but atleast u got one reply more than mine..j/k
rear with 295/30R21: Package is 1'' closer to suspension/brakes components. Package will stick out 0.9'' farther. Will fill out the wheelwell by extra 4 mm.
front with 245/35R21: Suspension: 100% clear (leaves even more room than OEM) Package will stick out 0.1'' farther. Wheelwells is the same.
You may calc with other tyres here: http://www.rimsntires.com/specs.jsp
I compared stock 245/45R19 8.5J offset 35 with the above mentioned tyres and your wheel sizes.
