Tire pressure warning came on
I constantly keep the spare tire inflated at 40, which requires my attention every 4 months or so. The tire's pressure goes down by about 1 psi a week.
When any of the 5 tires goes below a certain pressure reading (I guess it's 27 or 26 I forgot what the number is), you should expect a warning message to come on. So you just need to inflate your spare tire or whatever tire lost its pressure.
I have been dealing with this problem for some time now. Here is what I have learned. My tires were going down from 1 - 2 psi every week or so. I went to Discount Tire and told them to check for nails in the the tires. The man at DT laughed and told me it was the chrome finish on the wheels that was the problem. He said that the chrome finish was bad on the wheels. If the rims were not properly chromed, the rims will not seal completely. He also said that I would need to buy a new set of wheels and don't buy chrome. I talked to several people about this. I was told by a company( US wheel exchange) on ebay that permachrome PVD was the way to go as far as chroming the rims. The company said this was a new process and was far better than the usual chroming process. Has anyone else had these problems with their chrome rims or heard of the PVD permachroming process.
Thanks for all your help
jarm
jarm
jarm
jarm
Just went to go take a look at it...the 5th tire is blinking at 15 PSI...walked around the car and the right front passenger has lost all its air..WTF>?
The spare is hard as a rock......just called Roadside...is it possible the 5th tire blinking is for the front right?
Roadside is on route
the numbers ordering has NOTHING to do with which tire is which. it doesn't tell the location. one tire rotation and everything can change. you will have to go figure out which tire is which.
what do you mean they changed the front right tire? you mean they swap that wheel out and put on the spare? if so, all you need to do is to patch or get new tire for the one that you have flat. once it has good pressure the light will go out. i have changed a lot of tires and never have to reset any lights
Yes swapped for the spare....I will get a patch and see if it goes off..thanks Henry
jjparker
04-25-08 02:39 PM
