audio off delay
10th Gear
audio off delay
Is there a way to delay the audio from turning off when the car is turned off? Sometimes when I get to where I'm going and I'm really enjoying some music, I want to sit there for a few minutes and indulge in that Mark Levinson sound..without keeping the car running. In my Jeep, the audio stays on until you open a door. Is there a way to do this on the LS? Also, while I'm at it, is there a way to have power to the acc outlets when the car is off?
Yes. You can put the car in Neutral, instead of Park, and turn the car off. Engine will shut down, but your radio will still play. You will have to hit the ignition button again before exiting the car for good, but it gives you what you want w/out having to run the engine.
What I usually do is I park the car, turn it off and press the ignition button once without depressing the brake pedal. Then when I want to get off the car, I just press the ignition button once again.
I do it at gas stations, when I'm waiting in the car ...etc
Johnnyz4
12-03-10 07:24 PM
