LS460 from a Private Owner
I am in process of buying a SWB from a private owner, 2007 with 33k miles. Still under waranty and has the extended warranty that cover up to 100k miles bumper to bumper. Any pros and cons with buying from a private versus a CPO? It should be safe right since it is still under warranty? Any advice would be appreciated.
get a list of all the services performed on the vehicle, they should have these and if they were done at Lexus then he can request it from his dealer. There were two (now 3) recalls on the 07 so make sure the idler pulley and fuel pipes were taken care of, if its 3 years old they should have maintained it to the point where all you need to do now is handle the valve spring replacements if your VIN is within the range. its also a good idea if you dont know what to look for to get a 3rd part to inspect it to make sure it has not been in any accidents. CarFax is not reliable from what I have found over the years. Too many side deals going on with independents and shops that are willing to not report damages etc. Just make sure you know what you are buying.
You can find more info on CPO specifically at http://www.lexus.com/cpo/overview/index.html
It sounds like it has the platinum and it's bumper to bumper 7 years/ 100,000 miles. It's the best warranty you can buy from Lexus. Make sure it's the platinum warranty. It doesn't cover the battery after the four years, or any maintenance items. It's a good warranty and I have it on both of my vehicles...
As long as you get the service history, make sure the recalls were done, have an independent shop or a dealer inspect the vehicle prior to purchase and also have a body shop inspect for prior paint work/non-reported cash repairs.... then yes it can be a great deal to buy private.
Well, I called the guy and he is a Lexus broker. I've never dealt with a broker before but can they be trusted? The car is really clean, lease return with all maintenance records. See warranty below. What do you think?
Extended Vehicle Coverage by Express Autocare
A Bumper to Bumper Warranty that starts the day you buy from us.
Supreme Coverage
Powertrain
Engine Cylinder block, cylinder head(s) and all internally lubricated parts contained within the engine including: timing chains; timing belt; timing gears; cylinder head valves; valve springs, seals and gaskets, seats and retainers; water pump and factory installed turbochargers.
Transmission (Automatic or Standard) Transmission case and all internal parts plus: torque converter; vacuum modulator; electronic shift control unit; transmission cooler; transmission mounts; oil pan; seals and gaskets.
Transfer Case Transfer case and all internal parts; seals and gaskets.
Drive Axle (Front and Rear) Drive axle case; all internal parts contained within the drive axle; drive shafts; universal joints; bearings; differential cover; seals and gaskets.
Cooling Engine cooling fan and motor fan; fan clutch; radiator; heater core, thermostat and blower motor.
Steering All internal parts contained within the steering box; rack and pinion gear; power steering pump; hoses; steering column shafts and couplings, including tilt-wheel mechanism; steering box; rack and pinion gear housings; seals and gaskets.
Brakes Master cylinder; power brake cylinder; vacuum assist booster; hydro boost; disc brake caliper; brake hydraulic lines and fittings; hydraulic control unit; seals and gaskets.
Electrical Alternator; voltage regulator; starter motor; starter solenoid and starter drive; computerized timing control; electronic ignition module; ignition switch; front and rear wiper motor; headlamp switch; turn signal switch; heater/air conditioner switch and blower and horns.
Fuel Delivery Fuel pump; fuel injection pump and injectors; vacuum pump; fuel tank and metal fuel delivery lines.
Air Conditioner Condenser; compressor; lines and hoses; expansion valve; pressure cycling switch; seals and gaskets.
Front and Rear Suspension Upper and lower control arms; control arm shafts and bearings or bushings; ball joints; radius arm; torsion bars and mounts or bushings; struts; spindle and spindle support; wheel bearings; seals and gaskets.
Enhanced Electrical Automatic climate control programmer; electronic instrument cluster; mileage computer; distributor; ignition coil; cruise control module; powertrain control module; power window and power seat motors; power mirror; power antenna and power sunroof motor.
Supreme Coverage
Powertrain
dormie
11-17-10 04:04 PM
