bmw wheels on 460
bolt pattern is good
whether the m6 wheels clear the front caliper, i can't say for sure (probably will, that's just my guess).
another thing is hub bore size, bmw (5, 6, 7) are 72.5mm i believe. maybe you will need hub rings
again it was just going to be a super cheap upgrade to the stock 18s. i have a buddy whiling to sell me a black set of the 20" with tires for 650. i spend that on a good night out. better then stock 18s. ill just take the time and slap em on quick see where the offsets sit and if it looks retarded.
hub centric rings can be custom made for any combination, that will take care of that hub bore issue. hopefully the bmw wheels have a smaller size..usually hub rings will "fill the gap"
I just did a basic google search and found this
According to the TSW fitment guide
- 6 series including M6 center bore = 72.56
- 7 series center bore = 72.56
Then did another google search for centerbore charts and found this which says the LS has a 60.1m center bore.
http://www.roadkillcustoms.com/hot-r...CIAL+OFFSET%29
This shows the specs for the 6 series
http://www.roadkillcustoms.com/hot-r...odels=6+SERIES
This shows the specs for the 7 series
http://www.roadkillcustoms.com/hot-r...%2C+750%2C+760
So getting hub rings may not be an issue, then all you need to worry about is bolt pattern matchup, then offset and width to avoid rubbing. I know discount tire direct dot com is another resource for hubrings..tell them to match up and they may be able to hook you up..if not, there are other places that custom make hub rings
I wouldn't personally put another car's make wheels on my car, especially LS, which is classy on its own. BMW drivers might make negative comments haha, try it and see how it goes!
