Datasystems ASR681 Installed - Anyone have knowledge of operation??
Old 10-11-10, 07:57 PM
FoxCars
FoxCars's Avatar
Exclamation Datasystems ASR681 Installed - Anyone have knowledge of operation??
I have the ASR681 installed and working in the LS600hl BUT I can't get out of normal mode. My instructions are in Japanese which I can't read...haha. I really need some help how to get into the extreme mode so I can slam the car before it leaves for SEMA on Thursday night. My box that is wired in works and only have H1 & H2 setting with 0-5 (Zero being the high and 5 being as low as it can go in normal mode) which works perfect.
Could someone call me who knows how to work this and school me how to work it?? Or you can Email me at brian@foxmarketing.net anytime.
I really appreciate the help boys and will give you a ton of credit for the help at least.
Old 10-11-10, 11:16 PM
rominl
exclusive matchup
rominl's Avatar
car shut off
press and hold bottom left button
start the car, wait for beep
use right buttons to select super L mode. press lower or upper left button to confirm
you are done
Old 10-14-10, 11:30 PM
JSTALEX
JSTALEX's Avatar
I love my lowering system!
Old 10-29-10, 06:44 PM
reagor500
reagor500's Avatar
Default reagor500
Hello all, Looking for some info regarding lowering module for 2007 LS460L
I am really curious in how this system works.
Old 10-29-10, 08:01 PM
305Busa
305Busa's Avatar
I love mines as well. I get a kick out of seeing the look on peoples faces when Its parked and the 22s are tucked in the wheel well.
Attached Thumbnails Datasystems ASR681 Installed - Anyone have knowledge of operation??-tolypic50.jpg
Old 10-29-10, 10:28 PM
rominl
exclusive matchup
rominl's Avatar
basically it's plug and play and there is a digital display controller you use to adjust the ride height of the car
Old 10-29-10, 10:39 PM
JSTALEX
JSTALEX's Avatar
Looks LOW! Is that bottomed out?
Old 10-30-10, 12:35 PM
305Busa
305Busa's Avatar
Wont bottom out. The car actually sit on the tires.
Old 03-16-11, 06:32 AM
LucidSnow
LucidSnow's Avatar
since i the initial setup for the asr681 is different then the asc680 i am posting this to let future asr681 users know how to set it up and use it. heres the steps i was guided to follow by "FoxCars" users here on clublexus forum. this can be done anytime you have the car started to reset chasis or set height.
1.start car
2.(must use wireless controller to set it up to have it linked to the wired module)
wireless controller hold all 4 buttons down or both downwards buttons until it beeps then u will see testing mode on the screen, if u hold it longer it will show ver 1.6 on the screen.
3. now ur on the screen to setup which chassis car model u have. for my ls430 05 its 7E i beleive. so press up or down until u select ur model then press mode to set it.
4. now ur on the screen to setup which mode u want to run it in. srd or spl . of course we would want spl , then press select button to set it up.
5. now ur on the h1 or h2 set height screens. with asr theres only normal / h1 / h2 settings you can save. in h1 click select and it will blink all 3 variables. choose ur height accordingly and press mode to save. if you wish to go to super low mode, press down until it hits 9 then hold down until it beeps and ull be in L mode.
so hope that helps the future asr681 users. and special thanks for FoxCars once again for helping me out.
badumtums (12-19-23)
Old 07-10-16, 07:53 PM
myroncuz
myroncuz's Avatar
I notice last poster is talking about ls430's. does it apply to ls460s? thanks
Old 08-29-17, 04:25 PM
SharksCity
SharksCity's Avatar
1.start car
LucidSnow how did you get the wireless module to sync with the main module?
Old 12-30-20, 05:15 PM
Hosed
Hosed's Avatar
I need this answer as well
clammbo
11-07-21 04:46 AM
AMACK
06-05-18 03:24 PM
spikerjack
06-15-11 01:08 PM
junjdm
07-03-09 01:32 AM
mhenrey
11-14-08 04:03 PM
Quick Reply: Datasystems ASR681 Installed - Anyone have knowledge of operation??
