Mark Levinson Amp Repair
Old 07-12-15, 01:31 PM
  #91
macjac69
macjac69's Avatar
Default ML amp repair
Well, sent my ML amp off to United Radio on Fri. God I was hoping by some blessed reason i could come across an alternative that wouldn't be so expensive. By far the costliest repair to my LS thus far......smh.
Old 07-13-15, 07:17 PM
  #92
dlbuckls10
dlbuckls10's Avatar
My amp was replaced under warranty. Otherwise I would have cost me about $1000 at the dealership.
Old 07-23-15, 10:00 AM
  #93
macjac69
macjac69's Avatar
Got it back from URP. Installed works as advertised. We'll see how long it goes for....
Old 07-23-15, 02:51 PM
  #94
Unsober1
Unsober1's Avatar
That was a quick turn around. Since the ML amp issue does affect may people. Please update status good or bad in the future. Also, This might be asking for too much information, but what type of repair was needed and what did your repair cost ?
Old 07-23-15, 06:58 PM
  #95
CRowe14
CRowe14's Avatar
There is actually a sticky about this specific topic.
From what I understand, if the amp was sent to the facility in upstate NY, Syracuse I believe, they say that the way that they repair it, it's highly, highly unlikely that it will fail again., and I think the repair, the last I heard was $700-$750.
Old 07-24-15, 08:12 AM
  #96
Tee
Tee's Avatar
Here is the link to what Crowe14 spoke of..
https://www.clublexus.com/forums/ls-...ml#post8448432
It's been a 14 months since United Radio repaired mine for $700 and has been flawless!
matttrue (05-03-19)
Old 07-24-15, 09:40 AM
  #97
macjac69
macjac69's Avatar
Don't know exactly what they replaced, guess I should have inquired as I did shell out $725. It's got a 1 yr warranty and they shipped it return in packaging that if I have to return it I can use same box. It actually seems louder(output) now that the new components are inside.
Old 08-09-15, 11:28 AM
  #98
alwal89
alwal89's Avatar
is this issue with LS 2007 - 2009 models or its also with 2010 -2012 models?
Old 08-09-15, 02:17 PM
  #99
Gbp
Gbp's Avatar
The amp (indicated by part number) was changed in 2010, presimably to solve the blowout problem. A number of people have said that the newer ML systems have poorer bass response, compared with the 2007-2009 ML system.
Old 08-11-15, 10:33 AM
  #100
hhss
hhss's Avatar
Just had my amp repaired by United Radio a few weekends ago, total damage was about $700 plus tax and another $130 to ship it from where I am in Canada. Anyone know why they are charging more then before ?
Old 08-11-15, 12:50 PM
  #101
SikLexus
SikLexus's Avatar
So i assume United Audio will fix the Non-ML amp as well? I think my amp went out in my 07 is350. At start up i would hear the rear passenger speaker pop every time i turn on/off the radio? Will this be the amp issue? The radio comes and goes. If i was to turn turn it off and on about 10-20 times the radio will sometimes start working again.
Old 08-14-15, 08:38 AM
  #102
Tee
Tee's Avatar
You need to give UR a call an ask if they service non ML units.
Old 10-23-15, 06:55 AM
  #103
GregCon
GregCon's Avatar
Well....my amp failed this morning with the dreaded chirping sound. I called United and they are still able to repair them, the price will run $400-900 depending on the serial number of the unit.
I gotta say...my LS460L has been the most babied car I've ever owned, and the least trouble-free. I really think Lexus took a turn for the worse around 2007 or so, their quality aint' what it used to be. My '95 SC300 was like a hand-built car of jewel-like quality, both mechanically and cosmetically. My '05 GS300 was like an anvil - not a single failure of any sort in 95,000 miles. But the LS has been a non-stop experience in breakage. And the loaner cars I get from the dealer also seem flimsy and superficial.
Old 10-23-15, 08:14 AM
  #104
roadfrog
roadfrog's Avatar
That sucks. United will get your amp up and running....hopefully at the lower end of the price bracket you were given. I'm surprised that you've had these issues you speak of. My '08 with nearly 100k miles has been trouble free and easily the best and most reliable car I've ever owned. Water pump and mufflers are all I've had to deal with. I think I'm the only member here at CL who has had to replace the muffs.
Old 10-23-15, 10:23 AM
  #105
lexus600hl
lexus600hl's Avatar
whats with $725?
I thought the earlier/older/ posts said flat $325..
Quick Reply: Mark Levinson Amp Repair
