Corner "Nike" and Fog Light Replacement Pics
Old 10-23-10, 11:38 PM
PRSUIT460
PRSUIT460's Avatar
Looks great! Looking forward to changing out those lights on my 460!
Old 10-24-10, 03:59 PM
Hoovey689
Hoovey689's Avatar
Very unique. I like it!!
Old 02-20-11, 05:41 PM
jbrittmart
jbrittmart's Avatar
V-LEDS has them in a bunch of colors.
they're the best LED company i've used... the brightest i've seen.
http://www.v-leds.com/194-168-158-LED/c506139-1-2/
i'm gonna do this.
Old 02-20-11, 05:42 PM
jbrittmart
jbrittmart's Avatar
oh and i found these instructions to get to the bulb in another thread.
looks like you don't have to pull the bumper.
Originally Posted by Shibumi1 View Post
i did it without removing the whole bumper.. remove the grill (1) 10mm socket. the remove the plastic clips holding grille on each corner.then its easy as pulling the grille forward gently as u release the locking tabs (4).. once the grille is out you'll see a plastic trim w foam tucked behind the bumper trim on either side of the grille opening.bend it down then you'll see 2 wiring harnesses unclip them or bend the metal tabs holding them in place an you'll see the bulb socket reach in an turn it counterclockwise an pop the socket out.
CRSO (03-22-20)
Old 02-21-11, 06:28 AM
PRSUIT460
PRSUIT460's Avatar
I ended up ordering http://www.v-leds.com/Interior-LED/G...04828-1-2.html
Old 02-21-11, 11:14 AM
I8ABMR
I8ABMR's Avatar
your car sounds pretty hooked up from the signature. Can you post some normal pics of your ride??
Old 02-21-11, 02:49 PM
adamls2
adamls2's Avatar
how much would this cost for the dealer to install each or both of them??
Old 02-22-11, 04:55 AM
Tee
Tee's Avatar
I have some LED 194's, I'm trying this mod this weekend.
Old 02-23-11, 07:56 AM
blackz405
blackz405's Avatar
Please take some pictures for us. One of my corner bulbs needs to be replaced. Thanks.
Old 02-23-11, 10:21 AM
Tee
Tee's Avatar
When you say corner bulb are you refering to the side marker light?
If so that is easy to replace.
Turn your wheel inward, remove the fender lining, then reach up and turn the bulb socket to replace the bulb.
Old 02-23-11, 12:46 PM
blackz405
blackz405's Avatar
I need to replace the clearance (nike shape) light.
Old 02-24-11, 11:10 AM
cmasten
cmasten's Avatar
Originally Posted by melymel96
I didnt do it myself, but I know for sure the front bumper has to come off. Last time I took it to the dealer they did it for me.
Curious if your guessing here or you saw them drop the bumper , I just used Shibumi1's great write up to do this myself in about 20 min and from what I can tell, dropping the bumper would not even give you access to the area that the bulb resides in. Its on the top outside of the headlight assembly, from what I saw the dealer would access this the same way I did which is through the grille and the pull down plastic panels etc all look like they were made for access this way. It should be a 1/2 hour tops for a dealership to replace the bulbs on both sides. Taking the top engine covers off was more than half the time it took to do this.
Maybe they did it that way, but were doing other work for you that required dropping the bumper
Old 02-24-11, 08:53 PM
JSTALEX
JSTALEX's Avatar
Angry
Originally Posted by josephdoc
The top one is Piaa-H376... that helps a lot!
Product page from Autobacs:
http://www.autobacs.com/shop/g/g4960311238744/
The bottom pic looks like the regular 9006/9007...
Which set you put in for the Nike light? Top or bottom??
edit:
Autoback removed their web link, here is another link to Piaa manufacturer:
http://www.piaa.co.jp/products/car/l...ve/tera.html#2
Cost and link where we can buy these???
Old 01-13-17, 07:22 AM
Ricks619
Ricks619's Avatar
Originally Posted by JSTALEX
Looks very nice!
Looks great, I was looking into doing mines too. I was told you could use 921 bulb as well which is super bright which won't break the bank, but still little concerned on the power. It draws a higher current 1.4A at ltitle over 17watt compare to approximately 0.4A on the stock bulb.
bigblack06
03-22-20 02:54 PM
bigblack06
05-30-12 01:29 PM
IndecentSC
Florida Lexus Club
71
04-26-12 02:57 PM
steezy
CL of Hawaii
19
07-15-09 02:41 PM
NovaIS350
09-01-06 03:13 PM
Quick Reply: Corner "Nike" and Fog Light Replacement Pics
