Corner "Nike" and Fog Light Replacement Pics
I've had this done for a couple months now just havent had time to take some pics. I had the corner "nike" light replaced with some LED's I got from Japan and replaced the stock fogs with some new bulbs that burn to a closer color to the stock HID's.
It was sprinkling when I was taking these pics...
![Name: IMG_1009.jpg
Size: 20.3 KB](https://www.clublexus.com/forums/attachments/ls-4th-gen-2007-2017/460642d1501791993-corner-nike-and-fog-light-replacement-pics-img_1009.jpg)
![Name: IMG_1007.jpg
Size: 42.7 KB](https://www.clublexus.com/forums/attachments/ls-4th-gen-2007-2017/460643d1501791993-corner-nike-and-fog-light-replacement-pics-img_1007.jpg)
![Name: IMG_1004.jpg
Size: 56.3 KB](https://www.clublexus.com/forums/attachments/ls-4th-gen-2007-2017/460644d1501791993-corner-nike-and-fog-light-replacement-pics-img_1004.jpg)
![Name: IMG_0998.jpg
Size: 29.2 KB](https://www.clublexus.com/forums/attachments/ls-4th-gen-2007-2017/460645d1501791993-corner-nike-and-fog-light-replacement-pics-img_0998.jpg)
![Name: IMG_1000.jpg
Size: 59.3 KB](https://www.clublexus.com/forums/attachments/ls-4th-gen-2007-2017/460646d1501791993-corner-nike-and-fog-light-replacement-pics-img_1000.jpg)
That looks real cool, good job. Was it hard accessing the nike lights? I haven't attempted to look under the engine shroud covers. Are the light bulbs only accessible through the wheel well or from the top?
I didnt do it myself, but I know for sure the front bumper has to come off. Last time I took it to the dealer they did it for me.
WOW!! That looks so much nicer than stock! What type of LED bulbis that? HOw many mini LEDs on the bulb, etc. And those are halogen fog bulbs, not HID? Dang! Where can we get those..post up some links!! Great job!
I'm on my way to work but will sift through my email.
WOOT...
I want to change mine also. For long time that I feel bad to look at my ugly-yellowsih Nike logos (or "L" for Lexus) and thinking about a brighter solution but I can't find info about the bulb specs.
Plz do look into the bulb specs and let us know.
The following bulb specs I have is from Osram Sylvania but I dont see any thing about the front "Nike lights"....
Low beam headlamp
HID-D4S
High beam headlamp
9005
Parking light
2825
Front turn signal
992 (7440A)
Rear turn signal
7440
Tail light
LED
Stop light
LED
High mount stop light
LED
Fog/Driving light
9006
License plate
Assembly
Back up light
921
Front sidemarker
194
Rear sidemarker
2825
Map light
175
Dome light
DE3175
Step/Courtesy light
2825
Thanks,
Low beam headlamp
HID-D4S
High beam headlamp
9005
Parking light
2825
Front turn signal
992 (7440A)
Rear turn signal
7440
Tail light
LED
Stop light
LED
LED
Fog/Driving light
9006
License plate
Assembly
Back up light
921
Front sidemarker
194
Rear sidemarker
2825
Map light
175
Dome light
DE3175
Step/Courtesy light
2825
Thanks,
The top one is Piaa-H376... that helps a lot!
Product page from Autobacs:
http://www.autobacs.com/shop/g/g4960311238744/
The bottom pic looks like the regular 9006/9007...
Which set you put in for the Nike light? Top or bottom??
edit:
Autoback removed their web link, here is another link to Piaa manufacturer:
http://www.piaa.co.jp/products/car/l...ve/tera.html#2
From the list above, the Nike light would be:
Parking light
2825
which also cross references to the (194, 168, T10, 158) style number bulbs as seen here http://www.retrosolutionsllc.com/ser...94-1.5W/Detail
The PIAA part number doesn't correspond with the bulb type, but we know exactly which one to buy, so thank you for posting up those pics!!
The factory bulb type for fogs is 9006, which is a very common headlight bulb as well. The 9007's are quite a bit different, so you will always want to get a 9006 style bulb for your fogs.
Other Nike light LED options:
http://www.eautoworks.com/product-Polarg-14450.htm
http://store.ijdmtoy.com/Canbus-Euro..._t10_sku26.htm
http://www.v-leds.com/Interior-LED/G...04828-1-2.html
and I'm sure a ton of other places. Those PIAAs look really good tho!!
Parking light
2825
Found one set on fleabay.
http://cgi.ebay.com/ebaymotors/PIAA-...Q5fAccessories
It is about $20 cheaper if buying this in Jap..
