DRL swap
DRL swap
Has anyone swapped the drl bulbs for led or hid bulbs.. im doin a low beam & fog swap & id like the drl & corner bulbs to match (6k or 8k undecided right now)
will there be any issues by changing to hid drl's? also i saw this pic and was wondering how this was accomplished.. can u turn off the drl's? if so how.. i may not want them on all the time..
https://www.clublexus.com/forums/ls4...imo-ls460.html
hey henry.. what do u think about this... my only question is will it be strong enough to use as a high beam?
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
V-LED has phased out the kit that I used but thery made a new improved version but not in kit form, so you will have to order what you need separately. You will need to buy two light modules to boost the half pwr to full for the LED's to work.
http://www.v-leds.com/Exterior-LED/D...52845-1-3.html
http://www.v-leds.com/Exterior-LED/D...97704-1-3.html
exclusive matchup
umm, good question, i don't really know the answer as i didn't study much in led
but from what i read, using led for drl might need another vled module or something like that. because led is on/off device (either on or off), not like normal bulbs where if power is half, it operates at lower performance. so you might need another module to regulate the power supplied to the bulbs
on the link it does say "no error", but i don't know enough to say
GREAT PICS TEE... looks like i may give em a try... when i try em out i'll post some pics..( doin tint tomorrow, hids sat & smokin taillights mon-tues) i know how henry frowns on un-modded vehicle pics.... so i try to put em up in stages thx for all the help
