Tire with slow air leak
Old 01-25-11, 03:59 AM
randomwalk
randomwalk's Avatar
Default Tire with slow air leak
My rear tire has a slow air leak and eventually will throw the TPMS light. I'd put more air in and a couple weeks later same thing happens. I took the tire off and look for nail etc. Nothing is there to puncture the tire. Put some soap water on the valve stem and no bubble -- no leak there.
So what's the issue? Why is it leaking air? Any idea? This is happening on only one rear tire. The other three maintain pressure perfectly.
Old 01-25-11, 05:02 AM
KayGee
KayGee's Avatar
Your rim could be bent or if it is chrome it could be peeling around the bead.
Old 01-25-11, 05:18 AM
randomwalk
randomwalk's Avatar
I took the tire/wheel off the car for better visual inspection. Searched every inch of the tire...no nail or puncture that I can find. No chrome peeling because the wheel is not chromed. But there is no peel, chip, crack or bend on the wheel that I can see. I'm loosing about 3 psi/week for that ONE tire/wheel. The other three are are solid.
Old 01-25-11, 05:20 AM
dimapb
dimapb's Avatar
Put the tire in teh bucket of water. You'll see where it's leaking from. If you don't have a bucket to accommodate, go to a Gas Station or Tire Shop where the patch the tires and for $10 they'll find and patch the leak, as long as it's not a bent or peeling rim.
Old 01-25-11, 05:24 AM
randomwalk
randomwalk's Avatar
dmitry,
I don't have a bucket of water big enough but my neighbor does have a swimming pool...don't tempt me!!!
Old 01-25-11, 05:37 AM
dimapb
dimapb's Avatar
Go for it! LOL
Old 01-25-11, 07:42 AM
cmasten
cmasten's Avatar
If there are no visible punctures, nails etc, then I would have a tire shop remount it and put in a new valve. If it still leaks then it may be a hairline crack in the rim etc.
Old 01-25-11, 08:24 AM
JKN2000
JKN2000's Avatar
I had the same problem a few weeks ago. Tire shop took the tire off, and there was residue on the wheel that prevented the seal on the tire to be completely sealed to avoid the leak.. My tire was brand new and the leak kept going until the 3rd try. All they did was cleaned it up and it was fine. So far so good.. no more slow leak.
Old 01-25-11, 04:57 PM
june
june's Avatar
I had the same problem, It was the nut that held the valve sem on. Check the nut to see if it is lose.
Marty
Old 01-25-11, 08:47 PM
randomwalk
randomwalk's Avatar
What nut? I don't see any nut except for the cap
Old 01-25-11, 10:15 PM
june
june's Avatar
If you have a metal valve, the nut is on the valve stem next to the rim. It is how they tighten the valve stem to the rim.
Marty
Old 01-26-11, 05:42 AM
randomwalk
randomwalk's Avatar
Is the whole stem is the "nut" and you can just put a wrench in to tighten? See pic.
Old 01-26-11, 06:02 AM
ALSHUBCAPS
ALSHUBCAPS's Avatar
just bring it to a tire shop & let a "professional" do their job
Old 01-26-11, 02:55 PM
june
june's Avatar
That is the nut assy. It takes a 11mm socket. Just put it on and tighten it, if it is lose. If it is tight then you have a leak some place else.
Marty
nosurprise
06-13-15 05:36 PM
MVB
01-12-11 10:40 AM
sleekbrian
08-02-10 02:49 PM
wolverine
Wheels, Tires & Brakes Forum
02-07-08 05:39 AM
SGT
04-28-06 08:23 AM
Quick Reply: Tire with slow air leak
