Headlight issue
Headlight issue
I have a 07 LS460 SWB with 51k. The right side headlight comes on as it should for about a minute then goes out. I'm not sure if this is a bulb issue or a ballast issue. Any thoughts or ideas ?
you can pay a lot more for the german bulbs, but I get the same or better life and same light output out of the these, good reseller up in SF too
http://cgi.ebay.com/ebaymotors/NEW-G...Q5fAccessories
nothing wrong with ballast, this happened to me. HID bulbs will go out if they cannot maintain current properly then come back on. Just put in a new pair of bulbs. Get some OEM brand bulbs on Ebay and save a grip because they DO NOT cost over $100 each..you should be able to get a pair for way under that
Your ballast is fine, you need a set of bulbs (Always replace both for equal light output) and that will fix the issue. I had the same problem few months ago with the driver side flicker then would go out, I would turn off the lights and turn them back so it would light up again. I was told by tech that the first run OEM bubs were defective and they replace a lot under warranty for customers on 07 models, problem is they only replaced one bulb.
Teachustea
11-25-16 06:18 PM
Panerai127
01-31-07 10:27 PM
