LS 460 Sport 2011 Matt Wood Trim and 19-in split-10-spoke forged alloy wheels
These are the wheels I am talking about. A pic from the Lexus website.
If they are not available as an accessory, perhaps they can be ordered as a replacement part using the VIN number of an actual LS460 sport as a reference?
Perhaps sponsors can chime in on prices, discounts, availability.
Thanks
Thanks
the wheels will def fit with no issue. Try our vendor on here for Sewell Lexus. Troll around on ebay, sometimes a new owner will sell the oem wheels if they put different aftermarket ones on. Since this model is new, i don't think there are an abundance of these wheels out there just yet. They will be eventually.
I believe our club lexus POC at Sewell is Darrell
Sewell Parts at Sewellparts.com
6421 Lemmon Avenue | 5100 Bryant Irvin Road
Dallas, TX 75209 | Fort Worth, TX 76132
Tel: 888.909.6633 | Fax: 214.276.1983
Email: lexusparts@sewell.com
How about the ISF wheels....perhaps easier to find?
I noticed they are staggered:
F 235/40 19
R 255/35 19
Perhaps the front will be too narrow so I can use the rear size on all four?
F 235/40 19
R 255/35 19
What are the implications of this? Since the ISF / LSS wheels are designed for larger brake clearance & I have the smaller brakes on the LS460, their wheels should easily fit?
Not sure about the offsets though...
NO GO on the IS-F wheel thought. Our LS's have 5x120 bolt pattern, the IS-F is 5x114.3 aka 5 on 4.5.
IS-F Wheels:
* Size: 19 x 8 Front, 19 x 9 Rear inches
* Bolt Pattern: 5-114.3
* Offset: 45mm Fronts / 55mm Rears
* Weight
* Accepts TPMS Sensors
from http://my.is/forums/f95/oem-wheel-sp...ackage-382622/
IS-F Wheels:
* Weight
IS-F Wheels:
* Weight
IS-F Wheels:
* Weight
stupid me
another problem is the offset of the IS-F wheels, our LS has 35mm OEM offset. The ISF wheels are nice..but they do they make adapters to convert the bolt pattern and they act as spacers too, but I wouldn't recommend you go through all that with the LS. Just another option you might want to consider, I have the Lumarai Morro wheel which are specifically made for Lexus vehicles including the LS. If you want OEM fitment, use OEM lugs, TPMS and center cap..then those are a good OEM alternative. I did 20x8.5 all around, but they do have the stagger option with 20x10 in the rear. They only make one style that comes in silver, black or chrome, but I really like them on my LS.
![](https://www.clublexus.com/forums/attachments/ls460-ls460l-and-ls600h/197114d1295473824-pics-got-the-new-wheels-on-finally-newwheels.jpg)
I really like the Lumarai idea and perfect fitment is a must for me - thats why I was only considering Lexus wheels.
However, I wanted to move away from the 5-spoke look into a busy design like 16 or 20 spokes and that look is present on the LS460S wheels. Unfortunately, ISF wheels are out.
Any other recommendations on the aftermarket with multi spokes and perfect fitment?
Thanks
Thanks
i am not aware of any hub specific (60.1mm) wheels made for Toyota/Lexus other than the Lumarai. It would be nice if they had some other options, but I was ok with this design. I have had tons of aftermarket wheels on other cars I have owned, and I always had the best luck going with wheels made for the car. So its a personal preference. Many folks on here have aftermarket wheels which I'm sure have hub centric rings, etc to get the smoothest ride possible. Good luck. If you do go aftermarket, I would say Vossen for sure..some very nice wheel options
