corner light bulb swap
#166
lmao... i've done no less than 2 dozen swaps since the post.. but i work on car stereos allllll day anyway so im just immune now i guess...
but you guys all know how the heads turn when u drive down the block.. its like......
#167
2010 lexus ls460 nike lights help????
hi i was wondering if the bulb for the nike lights is easy to remove on the 2010 model becuz i did everything like on the older models and i didnt see no bulb at all .....please pm thanks
#170
#172
thanks for the pics and bulbs size info guys, so i ordered some 9smd, just came in the mailbox tonight when i got home from work, n i had to put them on right away!! i hope they last.....
#176
Lol..tell ya what, when you find out let Tee know ..we encountered the same issue..that is a deep opening so I am pretty sure it will require a bumper and headlight assembly removal and shake it loose..way more effort than what its worth..it won't hurt anything so let it rest in peace and get a new one
#177
This is what I used. Good luck!
#178
So my old led bulb fell in. I did not try the magnet idea, next ti e I take it apart maybe. Anyway I left it in, you cannot see it. For the new bulb I took a little electrical tape and taped the bulb to the socket. Hopefully if these fail I won't lose one.
#179
Did you guys know the computer throws codes when your headlights fail? Turning your lights on and off with the harnesses disconnected throws a recordable event in the computer and the next time they bring up your computer log it will show.
Just thought everyone should know...
#180
WARNING and UPDATE!!!!!
Everyone. After several months of having the 921 bulbs installed, I will need to recommend that you do not install these. Tee and I both have had burned out bulbs and I know in my case it was due to excessive heat. The 921s are 17 watts and there is simple not enough air space to keep these cool..even while driving. My bulb socket plug suffered minimal melting around the edges. So I replaced them today with 194 LEDs from autozone. They are 4 led with wide angle..not near as bright but will work for now. Here are the other sylvania mini bulbs that should fit and associated wattages..again..avoid 921s
Bulbs..
#168 = 4.9watts
#194= 4.6watts
#916=7.3watts
#906=9watts
#921= 17watts
#2825 & 2827=5watts, #922=12.5watts
Bulbs..
#168 = 4.9watts
#194= 4.6watts
#916=7.3watts
#906=9watts
#921= 17watts
