corner light bulb swap
#62
I would have to look again, but I believe the fronts are only the reading lights, whereas the back has a center dome and then reading lights along the sides. I dont remember using a festoon in the front only (2) T10s that had a narrow and shallow depth like this one. http://www.dealextreme.com/p/31mm-1-...t-dc-12v-51003
I can double check for you in the morning
#64
#65
One Festoon in the back dome
Two T10's in the front
I know that both of these bulbs will work, as I have them in there now, but I would not change too much in size on either if you want to try another one. The front areas are very tight and the back has more lateral room for the bulb, but the 1.25" length is all you have to work with
There are reading lights in both front and back that are turned on and off by the user, these bulbs come in a specially housed package, they look like they are not easily user replaced, but I have not attempted to take them out.
Also Mine is a 2007, if that makes a difference, you would need to just take a small screwdriver and pop the covers off to check
#68
i'm looking for Nike light replacements on this site.
anybody know what the T10 size is comparable to?
can't seem to find them on this website over on the left side where they have all the bulbs listed.
is there another number that is compatible with T10?
http://www.v-leds.com/Shop/Control/fp/SFV/32481
#73
i think i might try the amber bulb from V-LEDS
http://www.v-leds.com/194-168-158-LE...orLanding/true
can anyone confirm that a size 194 bulb will fit in the Nike light?
#75
You guys received the shipment from DealExtreme yet? I placed two orders. Boths aid shipped.. One doesn't have a tracking and the later one does...although tracking is not working (yet). Have not received either one yet.
