corner light bulb swap
Old 03-23-11, 08:01 PM
  #106
randomwalk
randomwalk's Avatar
Woot. Got all the packages today. Going to Vegas though. Will have to install next week
Old 03-26-11, 05:57 AM
  #107
marylandlp
marylandlp's Avatar
Default grille removal/bulb replacement
Originally Posted by Shibumi1
tabs are notched... (notched towards outer edge) so lift each tab (start in upper corner) and work ur way around 1 by 1 as u pull the grille forward...
I finally removed the grille yesterday.It wasn't as easy as i thought it would be.There are seven tabs that have to be released before the grille can be removed. Two claws(tabs) on each side of the grille have to be released from the slots in the fender piece between the grille and light housing,and three larger ears (tabs) must also be pressed and released.I had a lot of difficulty getting the 4 claws out of the the fender slots.
Old 03-28-11, 04:29 AM
  #108
PRSUIT460
PRSUIT460's Avatar
Originally Posted by Tee
What no pics!
Finally...
V-LEDS.com
Old 03-28-11, 04:50 AM
  #109
Tee
Tee's Avatar
Looks like they match your lows, Looks good!
Are they bright?
Old 03-28-11, 05:58 AM
  #110
Shibumi1
Shibumi1's Avatar
[QUOTE=CDW91;6260855]Finally...
looks great!!!!!!
Old 03-28-11, 09:17 AM
  #111
CJITTY
CJITTY's Avatar
they look good, can you get a pic with just parks on, no headlight?
Old 03-28-11, 11:59 AM
  #112
jbrittmart
jbrittmart's Avatar
they look great.
V-LEDS is a great choice.
i'm still gonna try out the amber ones to try and match my parking lights.
Old 03-28-11, 05:01 PM
  #113
Tdvlexo
Tdvlexo's Avatar
I got mine from v-LEDs also and they are bright.
Old 03-29-11, 11:24 AM
  #114
PRSUIT460
PRSUIT460's Avatar
Yes I will.
Old 03-31-11, 05:08 PM
  #115
randomwalk
randomwalk's Avatar
Installed it today. Man it's tight in there. Light is okay. Not as bright as I would like.
Old 04-01-11, 08:16 PM
  #116
CJITTY
CJITTY's Avatar
not sure what's going on, but still fkn waiting
got amber leds though..those may be what I end up using because the other while leds from Deal Extreme are in postal cyberspace
Old 04-04-11, 08:15 AM
  #117
Grisik
Grisik's Avatar
I noticed the factory bulb is shaped like an L. All of the LED bulbs seem to be straight. I'm assuming that the wire and conector are long enough to have everthing fit back together correctly. I just don't want to get everything apart and find out I have the wrong bulbs.
Old 04-04-11, 10:22 AM
  #118
Grisik
Grisik's Avatar
Forget the last post. Took them apart and everthing worked great. It looks so much better with the LEDs
Old 04-04-11, 10:53 AM
  #119
Tee
Tee's Avatar
COOL! What color LED's are you using white or yellow?
Old 04-04-11, 11:03 AM
  #120
Grisik
Grisik's Avatar
T10 1.9W 6500K 171-Lumen 38-SMD LED Car White Light Bulbs. Thought they were going to be to long, but they fit.
Quick Reply: corner light bulb swap
