Fuses
The owner's manual says there are two and both are 15A.
One is located within passenger's side instrument panel: Fuse #5 (P-CIG).
Second is located in the trunk (left side under a cover): Fuse #6 (RR-CIG). I suspect this one is for the back seat socket, but the manual doesn't specify.
There is also one for the "Power outlet" under the arm rest in case you really meant that one; it is also 15A and located within driver's side instrument panel: Fuse #5 (PWR OUTLET)
Awesome! Thanks! All these years later, valuable info.
JohnnyCake
09-22-14 01:58 PM
