Camber Adjustment??
Camber Adjustment??
Does the LS460 have camber adjustment on the wheel alignment? I finally upgraded from my GS to an LS and wanted to also drop my LS and put some 21's on it. I remember with my GS430 that when I dropped it the tires had considerably more wear on the inside as the GS did not have camber adjustments.
there is no way to get adjustment to the camber settings unless you get modified camber arms that are adjustable. ive heard that there is not a lot of wear when doing a mild drop for the LS but if you are going to be slammed or go lower than whats ideal to drive around in then you might have some abnormal wear. like stated above TOE is the most important thing. how much are you planning to drop?
btw, i found rca's for 16 aristo in a quick google search. i don't know how good the pricing is on these ( 24,500 yen):
http://translate.google.com/translat...n&hl=&ie=UTF-8
also, if you're only lowering it an inch, you'll be fine with regards to camber -- my car's lowered maybe 3"? 4"? and the camber was only -1.6* and -2*. be absolutely sure your toe is spot on, though
you should be fine with around 1 in. doesn't affect the camber that much to do any damage at 1 in. you should look at tanabe springs...they seem to be really popular
