Battery Issue
#31
Over the last four years, I have also been very impressed with JMCraneys' postings. His analysis is so sequential coupled with his vast technical knowlege. If he wasn't retired, I would be sending our HR people after him; he would be/is an asset to any organization.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
#32
1 Post
Thanks JFNash, however, I am having trouble getting to the secret screen. To reiterate: Push and release "Disp" button then touch the screen in the upper left corner / lower left corner / upper left corner / lower left corner . Nothing seems to happen except with each touch of the lower left corner the screen contrast control lightens things one notch. Could the screen access be changed for the 2011 model year? I remember during the first service for the car the technician did seemed to access a different looking screen, black characters against a green background I think. I don't know how he did this.
Mike
Mike
#33
Mike:
This is a video I found on YouTube that shows you how to do it:
http://www.youtube.com/watch?v=ag3gtCwVtx8
#34
Location: Vancouver Island, BC -ex Illinois &Toronto, ON
So in the video it shows up/down, up/down, up/down (i.e., the up/down sequence is done three times, rather than two) to get to the first screen.
Is that the trick?
Is that the trick?
#36
1 Post
Success! Thanks vancouverl and JFNash. It is necessary not to touch the screen far corners but on the map portion itself. My model year shows a different initial sceen than the nice video you posted JFNash. There is no "menu" to push in the upper right but the selections available lead to many other selections. I have no idea what most of them do/tell me but I did find the battery voltage of 14.1 V (remember the subject of this thread which I apologise for straying from somewhat). You are correct edarte. I misposted only two not three up/downs.
Now an nav override menu would be great!!
Mike
Mike
#38
To get back on topic, I just today had the lights stay on as well. After parking the car in the garage as usual and locking the door as usual the lights were still on after an hour when I went back into the garage. Pressing the lock button on the fob turned them off in the end.
It looks like sometimes the auto-lights off doesn't quite work.
#39
my guess would be a faulty relay under the drivers dash that is your culprit. If the electronics are working, but the relay is not, then it will "stick" in the ON position and maybe not consistently as you describe. The arming of the doors etc, may just be enough to nudge it, if this is the case, the dealer should be able to trouble shoot it. There is a whole process in the service manual
#40
i've noticed that leaving the ACC on (to listen to the stereo, etc) will drain the battery MUCH faster than any previous vehicle i've owned.
i have a fairly new battery and if i have the ACC on for more than 10-20 mins, the battery drains enough to where the car won't start (just clicking when you press the button)
#41
The headlight "Auto OFF" feature begins its timeout from when one of the front doors is opened. So, if you conducted your auto-off test without opening one of the front doors - by waiting in the drivers seat - then the headlights will not automatically turn off and will probably stay on until the battery is dead, or you conclude that they will not turn off and decide to move on. If you conducted your experiment by reaching through an open window, with the remote key in your hand and cycled through the ACC/IG-ON/IG-OFF, leaving it in IG-OFF with the headlights on in the Auto mode, you would get the same results - eventually a dead battery.
#42
#43
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
#44
Can more owners comment on how this 10-20 minute kind of battery drain period relates to their experience? It sounds really extreme to me. I know my previous LS could easily go for an hour. I occasionally will listen to the ML while waiting on my wife. And I know the day will come when she shops for more than 10-20 minutes
so I don't want to find out I need to call for a boost.![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
#45
i've never had much luck w factory batteries. i use and recommend Optima "red top" batteries (1000cca) they come w a 3yr warranty.. but the best part is the low internal resistance.. which means ''if'' it does go low it takes less time to charge back up..
ex: after that 1hr of detailing the car.. how long do u run the engine b4 closing everything up? most batteries would take no less than 35-40 mins (@2500 RPM) to return to a normal state of charge (80% or better) optimas can do this in half that time..(at idle)
