Would these wheels fit on an LS460?
Registered User
Do you guys know if this combo would fit on an LS460?
5x120 tire size 275,35,20 Front 20x9.5, Rear 20x 10, came off a BMW 740i.
They are HARTGE wheels, would they look werd German to Japan car?
Input?
Thanks
Input?
Thanks
Registered User
I knew you would ask that..lol I'm trying to find out from the seller also...
Maybe you all can tell me what would be a good offset to start with for either 20's or 22's depending on width.
I did some searching and what I recall was for 20's depending on the width,
+19 would be a good starting point.
I don't have air suspension so plan to go the Tanabe spring route since this is my business car. I live in Northern VA, so I'm wondering if I should even do this as I'm probably going to have to raise the car in the Winter or go ahead and get a beater and garage it during armagedon lol and also hand washes from now on.
Thanks all!
Thanks all!
Well, I'm the wrong guy to advise on aggressive offsets. I believe our stock offset is 35. My Lumarai's are 20x8.5 and 31 offset. But I kept my setup very conservative..we got some folks on here that have some experiences that can help..most of these folks seem to comment more at night lol
great point! LS and most toyotas have 60.1mm hub bore..bigger than that and you will need hub centric rings to enjoy the ride at higher speeds without vibration or at least reduced vibration
Registered User
I have more info on the wheels if anyone has time to chime in if this would work would greatly appreciate it:
Front 20x9.5 - 245/35/20 either +36 or +38 5x120
Rear 20x10 - 275/35/20 either +36 or +38 5x120
Thanks in advance!
Thanks in advance!
