LS460 (non L) air ride? Lowering Module questions.
Old 04-26-11, 11:23 PM
msgs350
msgs350's Avatar
Default LS460 (non L) air ride? Lowering Module questions.
I'm considering going from a 3GS to a LS460 but have a question about the (oem) air suspension.
What year/model is it available in? Long Wheel base only? AWD?
How much is the lowering module?
Plug and play or do i need a shop to install it? If so how much do you think it will cost?
Thanks for the help.
Old 04-27-11, 08:22 AM
cheez80
cheez80's Avatar
it's "plug and play" but you do need to remove the front passenger's side glovebox, which is a pretty complicated thing to do if you haven't done it before -- my tech friend and i took like 45 minutes to take everything apart cause neither him nor i have done it before on a 600h. we even had access to the tis instructions, haha.
you can find the lowering module here: www.prestigioussociety.com
Old 04-28-11, 07:31 AM
adamls2
adamls2's Avatar
i believe it is only on the LWB until 2010 or sumthing?? not sure... i have a 08 SWB and cant do it :/
Old 04-28-11, 10:32 AM
patgilm
patgilm's Avatar
I have a 2009 AWD SWB and I have it. I believe it was standard on all 2009 AWD's. I can't remember but in either 2010 or 2011 it was not standard on all AWD's but was an option.
Old 04-29-11, 04:31 PM
AznRacer
AznRacer's Avatar
very good info in here
Paulanth
07-28-19 09:03 AM
Barberlife
05-26-19 02:28 PM
Amaterasu1
04-04-19 10:33 AM
DJWLDW
07-21-14 09:52 AM
riknchar
04-14-14 07:33 PM
Quick Reply: LS460 (non L) air ride? Lowering Module questions.
