LS seasonal tire pressure
I picked up my new LS 460L in January and the tire pressures were 33 lbs. As temps warmed up this spring, I noticed the pressures climbing so today, I finally went around with a digital tire gauge and adjusted the pressures back down to about 33.5 lbs. Probably show up as 34 on the dashboard.
My question is, do you normally let air out in the spring and add air in the fall? I'm in the Mid-Atlantic region so there are large shifts in seasonal temps.
I have the stock 235/50R18 Michelin Pilot HX MXM4 tires so I don't trust them in bad weather. Does it make sense to replace them before they wear out? I was thinking of getting the Continental ExtremeContact DWS.
I keep mine at 35 psi also. I can't tell the difference with 2 psi difference. The LS's ride is already pretty soft and compliant. No unusual wear so far running at 35 psi.
Some places have nitrogen to fill your tires. Nitrogen is a more dense gas so you won't need to adjust tire pressure as much, if any once the tire is filled. The pressure doesn't change like "regular" air does with the seasons, dependant on where you live of course. I remember when I lived in Germany and got my tires replaced at a tire place, the guy asked if I wanted air or gas. At the time I didn't know WTH he was talking about and couldn't get a good understanding of what he was talking about. So, I opted for the "safer" air. Now wish I had went with the "gas". With the extreme temps in GE I would have to adjust the tire pressure for the season. Hope this helps.
So to be sure that we're talking about the same reading conditions, the tire pressure reading needs to be taken when the car is cold.
When you drive the car even for a short distance, the air in the tires heats up and expands causing the reading to go up. So taking the tire pressure during or shortly after driving the car will give the wrong indication on what the tire pressure should be.
I use nitrogen. It's a cooler gas and doesn't expand much while driving. I have to add more nitrogen every 6 months or so (compared to 3 months with regular air). My target is 35psi. When I drive it reaches 40psi (especially when it's a hot day). So make sure you don't overfill the tires which may cause a problem when it expands.
Thanks for the responses! Very helpful. Nitrogen sounds like a great idea if I can find a place that offers it. I'll check around.
Update: Trying to check to see who's inflating with nitrogen, I came across this from TireRack:
Tire Tech Information - Clearing the Air About Nitrogen Tire Inflation
Also, Consumer Reports says there are benefits to using nitrogen but might not be worth it. Yes, you do lose less pressure by using nitrogen.
Unrelated side note: OMG, was just watching Motorweek at the NY International Auto Show and they showed a Lexus GS hybrid concept car with an ugly front end worse than the big Audi. Yikes, if that's a design trend, I'm really glad I got the 2011 LS. The concept if for a future GS but damn, it's ugly!
![](http://news.consumerreports.org/assets_c/2011/04/Lexus-LFGh-Concept-blog-thumb-240xauto-384.jpg)
I run mine at 44 psi. When they warm up I have seen them get to 46 psi. The manual recommend 38 psi I thought ( stock wheels)The cars weighs a lot and I am sitting on rubber band tires ( 30 profile in front and 25 series in the rear)
I am pretty sure that nose will not make into production
