Thoughts on this deal...my first post as well!!!
Hello all and glad I have found you guys. I am looking for an LS460. What do you think about this deal...2007 LS460 LWB with 41k for $43,900 CPO car. As far as upgrades go, not sure, can't tell much from the website. Will call tomorrow. Based on preliminary numbers...thoughts?
that sounds about right... make sure it has the Mark Levison package (it should say it next to the volume control (if you are into music its a must have) also check to see if it has the air suspension, there should be a switch that says height next to the traction control button in the center console (most LWB are equipped with it but few are not)
and by LWB this is an L model correct?
Colors combination?
I suspect you could find a cheaper one.
Back in May 2009 I found a grey-on-alabaster, non-cpo, fully equipped (with semi-aniline leather) 2007 LWB with 11k miles on it. The asking price was $52k.
That was more than two years ago and before the facelift and all the changes. So I think you could find a better option.
I believe it is Mark Levinson. Looks very clean and it has the 18's from what look like gs350 rims. I'm not sure what package that is. I think I can drop the price to about 42500 plus fees.
Also do they make LS460 SWB with air suspension. The reason I ask is I want to lower my car and put 22's on it and I feel air suspension is the best way to go about it.
No, the SWB does not have air suspension.
E92M3ZCP
02-27-15 06:55 PM
