I had mines in the center armrest. Made a small hole right under the aux plug/12v outlet and ran the wire thru there. It was facing up and held in place with 3M 2 sided tape. Then moved it to the ashtray like the pic above. Looks cleaner and its well hidden. Bought another ashtray on fleabay just in case.
So how hard was it to cut out the ash tray to make this fit? I looked at it and it looks like it will hit the cig lighter.
greetings Telmz1.
not hard, i just did mine today and you'll need a dremel tool with a cutting bit. you'll have a few mm of plastic adjacent to the cig lighter after cutting. mine fits tight, so i didn't use the bracket or screws.
greetings Telmz1.
Do you mind taking a picture so I can cut mine the same way?
