Data Controller Location
try this. mine is sitting in the glove box now, but i will attempt the relocation soon. the forthcoming instructions are from a post by ROMINL for a VAIS install, which will instruct you how to get to the ashtray.
"take out the 2 side panels, take out the littpe trim right in front of the center arm rest. 2 bolts for the shift plate on the driver side, pop it upward. pull the ashtray 45 degrees outward."
greetings Henry...for me it's a PITA. i'm always adjusting it since i ride on level 8 but have to change frequently if i anticipate driveways etc. for me, the ashtray is perfect.
I had mines in the center armrest. Made a small hole right under the aux plug/12v outlet and ran the wire thru there. It was facing up and held in place with 3M 2 sided tape. Then moved it to the ashtray like the pic above. Looks cleaner and its well hidden. Bought another ashtray on fleabay just in case.
since installing the module, i have'nt tried using the height high button on the center console (assuming that's what you're referring to). but that sounds like a plan, opposed to toggling through the module buttons.
my 22s are being made, so i'm rolling on stock tires, hence, level 8 in the front and level 7 in the rear. sometimes i forget to bring it out super low and don't realize it until i hit the driveway and spark my muffler!
i'm no baller...i just don't know any better! i'm learning as go (scraping up my car). as far as measurements, beats me. i have yet to pull out a tape measure, but if pushing the height high button is irrelevant, i'm going to need easier access to the module. hell, if the ride on super low wasn't so sh*7tty, i'd be on L all the time.
sup Henry & Cheez,
Wow, 8? I ride at 5 and that feels low but I have 22s. When I park it sometimes and I slam it, I'll use the HH button to get it up to a ridable height before touching the module.
i'm sure i won't get the same effect with the 22s. i really like how low it is now...maybe i should have went with 21s.
