CPO Warranty is about to expire, Inspection?
My CPO 100k warranty is about to expire. It's at 94k miles right now. I'm considering an inspection, either pre-purchase inspection or a mechanic to look it over. I want to make sure that everything such as bushings, engine, transmission, or other mechanical parts that need a 2nd look will be replaced by the dealership before the 100k mark.
Has anyone done this, and what would you recommend?
CL Folding Team Starter
- engine oil + filter
- check rotate tires
- check brake pads + rotors
- replace air con filter
- replace engine coolant
- replace smart key battery
- visually inspect pads, calipers and rotors (lol why would this not be included earlier)
- check installation of drivers floor mat (LOL)
- road test vehicle
- inspect axle shaft boots
- inspect ball joints and dust covers
- inspect engine air filter (i think this should be replaced...)
- inspect steering linkage and boots
- tighten nuts and bolts on chassis
You going to get another extended warranty?
BigDave
07-16-09 12:43 PM
ball, certified, cover, cpo, dealer, expiration, expire, inspection, joint, lexus, prewarranty, warranty
