Valve Spring Replacement Fears
Old 10-03-11, 09:02 PM
jlawr
jlawr's Avatar
Default Valve Spring Replacement Fears
So, I gotta know -- anyone ever have a problem after this safety recall was done? I am very nervous about having it done. I would really appreciate any input or opinions. Thanx.
Old 10-03-11, 09:23 PM
cmasten
cmasten's Avatar
My 07 runs better after the repair than before, I suspect my valves may have been out of adjustment as it would tend to put out a touch of smoke when I stepped on it.. that completely disappeared once I had the VSR performed and it idles much smoother now also.
No regrets..
Old 10-04-11, 03:47 AM
Silverpaws
Silverpaws's Avatar
9K miles after valve spring recall and engine could not run better.
Old 10-04-11, 06:39 AM
jlawr
jlawr's Avatar
Thanx for your replies.
Old 10-04-11, 07:35 AM
JFNash
JFNash's Avatar
20K miles after the fix. No problems, no regrets.
Old 10-04-11, 03:56 PM
Mikey100
Mikey100's Avatar
It's all GOOD and you'll be pleased.
Nothing to worry about.
Good Luck to all,
Mikey Lulejian
Lake Oconee, GA
Old 10-04-11, 05:11 PM
GammaLex
GammaLex's Avatar
Good Luck to all,
Mikey Lulejian
Lake Oconee, GA
Im glad you stopped with the blue it was hurting my eyes lol
on topic. You wont have any problems plus they will extend your engine warranty. They have a special tool just for removing valve springs from the LS lol
Old 10-04-11, 05:41 PM
cheez80
cheez80's Avatar
yep, 10k later the car's running great
Old 10-04-11, 07:32 PM
bsl888
bsl888's Avatar
Just go to the dealer you trust the most or has the best reviews in your area. Otherwise, nothing to worry about. Only the top technicians in each dealership is trained and given the task.
Old 10-05-11, 04:31 AM
Tee
Tee's Avatar
I think my LS drives better since the recall work, aslo have driven to DE from the ATL twice with no issues!
Old 10-05-11, 05:38 AM
40cpe
40cpe's Avatar
Mine was done this past January and runs well BUT my gas mileage has been off about 2-3 MPG since. The service rep says it had nothing to do with it but nothing else has changed. I know it is a stretch but I'm wondering if the heavier springs are the reason. If I had it to do over I would let one break first.
Old 10-05-11, 09:25 AM
vraa
CL Folding Team Starter
vraa's Avatar
I'm not sure if that's a good idea to wait for a valve spring to break when Lexus is replacing them for no charge......
Old 10-05-11, 02:05 PM
Nospinzone
Nospinzone's Avatar
Originally Posted by jlawr
I am very nervous about having it done. .
Frankly, I'd be more worried if I didn't have it done.
The only thing I did was wait until they had done a bunch of them so they weren't learning on my car. However, it doesn't appear as even this was an issue.
Old 10-05-11, 03:50 PM
vraa
vraa's Avatar
+1
unless your dealer is incompetent
Old 10-05-11, 05:11 PM
40cpe
40cpe's Avatar
[QUOTE=vraa;6729225]I'm not sure if that's a good idea to wait for a valve spring to break when Lexus is replacing them for no charge......
If the percentage of failures is as low as stated I would take my chances.
Quick Reply: Valve Spring Replacement Fears
