ECU Version
I also had mine done a while back.It helped with the idle smoothness and got rid of the way the car would put itself into neutral at stop lights to save gas
I understand. When you go to 'Menu' and choose the 'HHD Data' button, you can see the NAV Map and CDDB version numbers.
Is there a Menu to tell what version of the ECU Firmware is installed in the car?
bmorekid
11-02-10 08:36 AM
