Last edit by: IB Advertising
Browse all: Tires and Wheels Guide
- Tires General Information and Specs
Important information to help you understand your Lexus
LS 460/600 Wheel & Tire Information Details Thread
#151
Hello Everyone !! so i have a 2007 LS460 and i have been comparing it to a few other luxury cars which i feel are a little higher compared to the LS460 ( The ground clearance)
Now is it a good idea to have higher suspensions installed or can i get bigger puffier tires for this ? any suggestions ?? i see a lot of you have 22 inch wheels on the car which look amazing but is there a way i can install a little bigger tires on it or maybe on the 20 inch ones as long as the setup doesnt rub on the factory suspensions !!
thanks in advance
thanks in advance
#152
Jumped on the Tesla Wagon! Haven’t seen one on the facelift Tesla wheels. Pardon the lack of center caps.
Wheels: 21” Tesla Arachnid OEM wheels (staggered)
5x120
21” (Yes) hub-centric rings.
Fronts are 245-35-21
Rears are 265-35-21
No Rub.
Y’all’s thoughts? Good or bad?
russtayy (04-07-23)
#153
snakehead (04-17-23)
#159
This thread helped me choose my wheel size and tire sizes so I definitely wanted to contribute when as soon as I got my wheels installed. The fronts aren't as aggressive as the rears but I wanted to keep everything as close to stock without modifying the fenders. But I am more than likely going to rebarrel the fronts to either 2.5 or 3 inches.
LS Year/Model: 2009 LS460
AWD or RWD: RWD
Wheel Brand: Weds
Wheel Model: Krishna
Wheel Size Front: 20
Wheel Size Rear: 20
Wheel Finish: Chrome
Lip size front (if applicable): 2 inches (for now)
Lip size rear (if applicable): 3.5 inches
Lip finish (if applicable): polished
Offset Front: +29
Offset Rear:+29
Hub Bore size (if known): 60.1
Hub Centric Rings Required? Y/N: N
Tire Size Front: 245/40
Tire Size Rear: 265/35
Tire Make/Model: Westlake
Tire Air Pressure Preference: 38
Suspension: Stock
Fenders Rolled/Altered: No
Does the setup rub?: No
AWD or RWD: RWD
Wheel Brand: Weds
Wheel Size Rear: 20
Offset Front: +29
Offset Rear:+29
Suspension: Stock
The following 2 users liked this post by Jayson85:
Kdmc1LS460 (01-22-24),
#162
If the sensor is 10-12 years or older, it's going to fail soon and disable readings from all sensors. If you're asking if an 18" spare will work with 19" tires, yes but low speed driving and tire repair immediately.
#165
LS460 F-Sport Crafted Line 22" Wheels
I know I'm late to the party 🥴 but here's my LS!
LS Year/Model: 2015
AWD or RWD: RWD
Wheel Brand: Blaque Diamond
Wheel Model: BD-17-5
Wheel Size Front: 22 X 9
Wheel Size Rear: 22 X 10.5
Wheel Finish: Black Gloss
Lip size front (if applicable): N/A
Lip size rear (if applicable): N/A
Lip finish (if applicable): N/A
Offset Front: +30
Offset Rear: +30 (I think)
Tire Size Front: 245/35ZR/22
Tire Size Rear: 295/25ZR/22
Tire Make/Model: Pirelli PZ4
Tire Air Pressure Preference: 40F, 40R
Suspension: Data Systems ASR681II Set to 5F,6R
Pics Below:
LS Year/Model: 2015
AWD or RWD: RWD
Offset Front: +30
Pics Below:
