Old 12-15-14, 04:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Tires and Wheels Guide
Print Wikipost
LS 460/600 Wheel & Tire Information Details Thread
Old 09-25-23 | 08:36 PM
  #181
eem101's Avatar
eem101
3rd Gear
Default Data Controller
Can you share shop who installed your Data controller? I have LS460 2014
Originally Posted by AznRacer
LS Year/Model: 13 LS460 F-Sport AWD
Wheel Brand: Vellano
Wheel Model: VSO
Wheel Size Front: 21x9
Wheel Size Rear: 21x10.5
Wheel Finish: Matte Black
Lip size front (if applicable): 2.5 inch
Lip size rear (if applicable): 3.5 inch
Lip finish (if applicable): Gloss Black/Chrome Stripes
Offset Front: 35 roughly
Offset Rear: 40 roughly
Hub Bore size (if known): 66.56
Hub Centric Rings Required? Y/N: Yes
Tire Size Front: 245/35/21
Tire Size Rear: 285/30/21
Tire Make/Model: Michelin Pilot Sport
Tire Air Pressure Preference: 40 PSI
Suspension: Factory Air Suspension with Data Controller
Fenders Rolled/Altered: Nope
Does the setup rub?: Nope
Attachment 421831
Attachment 421832
Attachment 421833
Old 09-25-23 | 08:40 PM
  #182
eem101's Avatar
eem101
3rd Gear
I'm in FL as well & would like to install the suspension data controller.. If you can provide guidance I'd appreciate it!
Old 09-26-23 | 05:57 AM
  #183
eem101's Avatar
eem101
3rd Gear
I have a LS460. Can you share who installed the lowering module for your vehicle?
Old 11-08-23 | 04:37 PM
  #184
tmryan750's Avatar
tmryan750
4th Gear
Default 245 45 20 tires
Have 2016 awd ls460 currently have 245 40 20 tires and got a crazy deal on Michelin 245 45 20 set of tires, i dont really think slight high difference would be any issues just haven't seen anyone running this size , any thoughts are apricated.
Old 12-15-23 | 10:03 AM
  #185
mjw5879's Avatar
mjw5879
2nd gear
Smile Wheel drop for 4th Gen LS460L
Little late, but wanted to add my ride to the wheel drop thread! 22" Chrome Lexus ECLs with 255/30/22 tires
Old 12-15-23 | 10:09 AM
  #186
mjw5879's Avatar
mjw5879
2nd gear
Old 12-16-23 | 04:40 PM
  #187
Stephens's Avatar
Stephens
10th Gear
Default Kept it simple
I bought some "takeoffs: from a LS 500 - original Lexus chrome 20 inch rims .
Kdmc1LS460 (01-22-24)
Old 02-03-24 | 02:39 AM
  #188
Deividulis's Avatar
Deividulis
2nd gear
Default Wheels size
Hi! Can you tell me size of your tires? Suspension air?
Originally Posted by LexG
Upgraded wheels today. 22x9 Vossen VFS-1 Anthracite finish, ET 32.
Doublegrants18th (06-03-24)
Old 02-22-24 | 05:23 PM
  #189
naterdee's Avatar
naterdee
Default 2013 LS 460 FSPORT AWD - Nebula Gray - on 21" RF15 Staggered
LS Year/Model: 2013 FSport
AWD or RWD: AWD
Wheel Brand: Roadforce
Wheel Model: RF-15
Wheel Finish: Bright Silver w/Machined Spokes/Outer Lip
Lip size: CONCAVE Style
Offset Front: 28
Offset Rear: 40
Hub Bore size (if known): 60.1mm
Hub Centric Rings Required?: Yes (there 15 bucks)
Aluminum Hub Centric Rings Aluminum Hub Centric Rings
Tire Size Front: 255/40/21
0.3% difference in diameter for awd staggered=no issues
Tire
Size Rear:
285/35/21
Tire Make/Model: Accelera ST68 All-Season Ultra High Performance 102Y Front - 105W Rear
Tire Air Pressure Preference: 38psi front - 37.8 rear by asking following from CHATGPT lol. (SO basically 38x4psi)
"if you have 2 tires in the front of your vehicle at a size of 255/40/21 and 2 tires in the rear of the vehicle at a size of 285/35/21 there is a -.03% difference in overall diameter on the rear tires. If you have the front tires inflated to 38 psi, what psi should the rear tires be inflated to to make the overall diameter the same across all 4 tires."
Suspension: Stock air suspension
Does the setup rub?: Only if fully loaded and only at full turn in the front.
one in direct sun, one in shade...
-N8terdee
You can search forums for my overall diameter ls460 thread for more info. This is my third LS.
Old 04-08-24 | 08:31 AM
  #190
foleyjh10's Avatar
foleyjh10
1st Gear
I am shamelessly stealing your tire/wheel concept! Can I ask, what size hub centric rings did you purchase to install the tesla wheels on your LS?
Originally Posted by Talidtb
LS Year/Model: 2008 600hL
Wheel Brand: Tesla
Wheel Model: S
Wheel Size Front:21x8.5
Wheel Size Rear:21x9.0
Wheel Finish: Factory Silver
Lip size front (if applicable): N/A
Lip size rear (if applicable):N/A
Lip finish (if applicable):N/A
Offset Front: 40 (3mm spacer) 35
Offset Rear: 40 (5mm spacer) 37
Tire Size Rear: 245/35/21
Tire Make/Model: Federal
Suspension: Stock air (data controller system)
Does the setup rub?:No
Pics Below:
Old 05-28-24 | 03:07 PM
  #191
Diab's Avatar
Diab
Default 2014 LS460 Fsport AWD on staggered 22's?
Hi all, my LS460 f-sport is AWD and I have my eye on some staggered 22's, 22x9 front and 22x10.5 in the back.
Any insight on staggered wheels on a AWD, will it cause any axle or driving issues?
Old 05-29-24 | 07:38 AM
  #192
Diab's Avatar
Diab
Default Drilled rotors for a f-sport?
Where to get Drilled rotors for a 2014 ls460 f-sport?
Originally Posted by bfor3
LS Year/Model: 2017 LS460 F-Sport
Old 05-31-24 | 03:39 PM
  #193
lwphat66's Avatar
lwphat66
As long as you keep the overall diameter about the same, perhaps 1% or less difference, you should be fine. I don't have AWD, so maybe try searching the forum to be certain. I recall this being discussed over the last few years or so. Very nice ride brother, welcome to the family!
Diab (06-19-24)
Old 05-31-24 | 03:49 PM
  #194
lwphat66's Avatar
lwphat66
I've been running the Powerstop Z23 Evolution Sport Brake Upgrade since April 2020 when I installed them on my 2007 L. I'm rear wheel drive, but I think they have them for your AWD model, part# K5850. Evolution Brake Upgrade Kit for Daily Drivers | Quiet and Clean (powerstop.com)
Brake feel is great, low dust compared to the stockers, and I have not had any issues with them.
Diab (06-19-24)
Old 09-01-24 | 11:10 AM
  #195
Diab's Avatar
Diab
Default TOM'S VP-9 LS 460 F-Sport
The following 3 users liked this post by Diab:
hhss (09-09-24), jdmek998 (09-16-24), lwphat66 (09-02-24)
