Help! 08 LS 460 wont start!
Lately I have noticed my car struggling to start. When I put my foot on the brake to start it feels very weird. Do you think it's the battery??? Ugggggg
Could be low battery charge. I have just swapped the original panasonic battery in my car after 5 years. Everything went back to normal, including a weird shaky idle that was present just 2 days before the battery completely died.
In this post, #34, I explain which one I bought.
I just went in the garage and tried to start with no luck. I went to the battery and looked in the 'eye' and noticed it was red. It says to add distilled water to it? I am recharging it now. I guess my battery is not working property and I need to replace it if starts tomorrow morning?
The battery they yanked out of my car used distilled water? I thought that was pretty interesting. The new battery is a normal one with no distilled water.
Older lead acid batteries use sulphuric acid/water as the electrolyte. The water in the sulfuric acid is broken down into hydrogen and oxygen during times of battery charging. After enough charge/discharge cycles you need to replenish the lost water. You can use regular tap water if you have too, but the minerals in tap water over time will foul the lead plates in the battery. That's why the manufacture requires the use of distilled (de-ionized) water, it makes the battery last longer.
Most newer batteries are sealed and use a different chemistry.
I was told that lead acid batteries don't like to be drained; once their voltage drops below a threshold it becomes impossible to charge them back to the capacity they once had. Basically they like to be kept in a charged state. I dont know if it holds true with todays Lead Acid batteries-maybe someone can chime in on that.
akafixture
03-12-17 02:23 PM
