LS460 Adjustable Camber Kit online petition..let's try!!
Bottom line is that its a business decision. If they can get 20-30 people it may be profitable to make a limited run and charge up the *** for it. These companies will still need to design and produce a piece as well as to test it. The more I think about it the more i realize that it will be a bit harder than simply just tweaking the old parts
1. CJITTY 1/18/2012, 2007 LS460 SWB
2. brianlin87, 1/18/2012, 2007 LS460 LWB
3. Lextrician, 1/18/2012 2008 SWB 460
4. RuCuS81, 1/18/2012, 2007 LS460 SWB
5. cheez80, 1/18/2012, 2008 LS600hL
6. I8abmr 1/18/2012 2007 ls460
7. Adamls2 1/18/2012 2008 ls460 SWB
8. Mikey100 1-18-2012 2008 LS460 (swb)
9. FrankBoy 01-18-2012 2007 LS460 SWB
10. 305Busa 01/18/2012 2007 LS460 LWB
11.krzyd 01/18/2012, 2008 LS460SWB
12.Prsuit460 1/18/2012, 2007 LS460 SWB
13.
14.
15.
16.
17.
18.
19.
20.
13.
14.
15.
16.
17.
18.
19.
20.
13. yottabyte 1/18/2012 2007 LS460 LWB
14.
15.
16.
17.
18.
19.
20.
14.
15.
16.
17.
18.
19.
20.
Yeah..those help a little but if you can figure out something with those to give more than +2mm..we'd be in business..plus it has to be a solid modification on such a crucial part
When I put the oem and +2mm brackets side by side, I could not tell them apart other than the 0 and 2 stamped on each of them..obviously very subtle difference
14. bonafyd 1/18/2012 2008 LS460 SWB
15.
16.
17.
18.
19.
20.
15.
16.
17.
18.
19.
20.
3. Lextrician, 1/18/2012 2008 LS460 SWB
5. cheez80, 1/18/2012, 2008 LS600h LWB
6. I8abmr 1/18/2012 2007 LS460 SWB
7. Adamls2 1/18/2012 2008 LS460 SWB
8. Mikey100 1-18-2012 2008 LS460 SWB
11. krzyd 01/18/2012, 2008 LS460 SWB
12. Prsuit460 1/18/2012, 2007 LS460 SWB
15. More4my4 1/19/2012 2007 LS460 SWB
16. Tee 1/19/2012 2007 LS460 SWB
17.
18.
19.
20.
17.
18.
19.
20.
17.Shibumi1 1/19/2012 2007 LS460 SWB
18.
19.
20.
18.
19.
20.
