Location of ECU on LS460
Old 02-07-12, 01:22 PM
Jasoneo5
Jasoneo5's Avatar
Default Location of ECU on LS460
Do any of us know where the ECU is located? Can't seem to find my manual.
Going to have it shipped out to TOM's.
Thanks
Old 08-28-12, 11:06 AM
G-SharK
G-SharK's Avatar
Same here, can't seem to find where it is
Old 08-28-12, 02:48 PM
I8ABMR
I8ABMR's Avatar
if you are going to ship is this TOMS in Japan?? If so your ride will be out of commission for a long time until you get it back. Also I usually dont recommend doing ECU tuning by mail. Ideally they would adjust it, test it, adjust it, test it, until its perfect. I had a ECU retune on my G35 and I was at the shop for almost 3 hours before they nailed it
Old 08-28-12, 06:11 PM
Shibumi1
Shibumi1's Avatar
before i start.. i really suggest u have a certified MECP installer do ur install.. I AM NOT RESPONSIBLE FOR ANY DAMAGE DONE TRYING THIS YOURSELF...
that said:
the main ecu is behind the drivers side dash.. left of the column.. the entire lower dash must come off to access it.. the 10mm bolt beneath the parking brake switch(behind the black clipped in trim).. the drivers door jam trim. the wood grain panel beneath the drivers side a/c vent. the screw behind it.. the lower dash trim screws an panel must all be removed. then u'll see the main ecu behind the knee bolster... BE VERY CAREFUL NOT TO DAMAGE,UNPLUG OR SERIOUSLY DISTURB THE KNEE BOLSTER AIRBAG!!!!!!
Old 08-29-12, 12:49 PM
I8ABMR
I8ABMR's Avatar
That seems like some sensitive stuff. I think between the risk of damage, shipping it, and the down time of the car I would stick with the stock set up personally. But I will admit when they tuned the ECU on my G35 it was insane. It was like telling a beagle that it was a doberman
Old 08-29-12, 01:22 PM
G-SharK
G-SharK's Avatar
Actually, the main body ecu was easy to locate. I just overlooked it many times thinking it was a fuse box.
Old 09-01-12, 07:41 PM
PRSUIT460
PRSUIT460's Avatar
How much does Toms charge and what do they all do?
Old 09-01-12, 09:42 PM
adamls2
adamls2's Avatar
This may be a stupid question, but what does the flash do other than get rid of the limiter? Would be awesome to tune car with the cutouts open.
gtoden1
03-03-18 05:00 PM
Redeemed07
02-08-18 09:39 AM
dan200w
01-12-17 05:35 PM
cjohanne
02-24-10 09:02 PM
paul1234
Suspension and Brakes
09-23-01 10:04 AM
Quick Reply: Location of ECU on LS460
