2011 ls 460 playing random cd's
My boss is too lazy to read the manual. He complains that his 2011 LS is only playing 1 CD in random order. He would like all 6 CD's to be played in random order. I am not familiar with his system. Does it work like my 2006 SC430 whereby you hold the random button until it beeps and then all 6 cd's will be in random play instead of just one indivdual CD?
I appreciate your help. Thanks
In my RX, and I assume the LS is the same, if you hold the random button it will go to random all. It also works with the usb input and then it says fldr.rand on the nav screen.
1 Post
I assume he has the nav unit and therefore controls the CD player from the nav screen. Using the CD play screen here is the description of the RPT and RAND functions from the nav manual. I suppose this may also be too much for him to read so why don't you just read it to him!
... “RPT”: Use it for automatic repeat of the
track or disc you are currently listening to.
Repeating a track —
Touch “RPT” briefly while the track is playing.
“RPT” appears on the screen. When
the track is finished, the changer will automatically
go back to the beginning of the
track and play the track again. To cancel
it, touch “RPT” once again.
Repeating a disc —
Touch “RPT” for longer than a second
while the disc is playing. “D.RPT” appears
on the screen. When the disc is finished,
the changer will automatically go back to
the beginning of the disc and play the disc
again. To cancel it, touch “RPT” once
again.
“RAND”: Use it for automatic and random
selection.
Playing the tracks on one disc in random
order —
Touch “RAND” briefly while the disc is
playing. “RAND” appears on the screen.
The system selects a track on the disc being
listened to in random order. To cancel
it, touch “RAND” once again.
Playing the tracks on all the audio discs
in random order —
Touch “RAND” for longer than a second
while the disc is playing. “D.RAND” appears
on the screen. The system selects
a track on all the audio discs in the changer
in random order. To cancel it, touch
“RAND” once again...
Repeating a track —
Repeating a disc —
again.
selection.
order —
in random order —
