Aftermarket wheels question?
My first question is, what aftermarket lug nuts are you guys using? Because it seem there's not too many option in 14x1.5. And my second question is for those of you who are running 22's, why are most of you using a 25 profile tire in the rear? Because you want to keep it close to stock size? Anyone using a 30 series in the rear? I'm sketched out about about using a 25 series tire on such a big car.
I had to cop some gorilla tuner style lugs because my wheels wouldn't allow for oem.. being that said I guess it depends if you have wheel caps or not. 25 series dont look any different from 30 series but I think it is to try to keep as close to stock as possible. If you plan on lowering your car, that make a difference if you rub or not. There are other brands like project kicks, muteki, rays and etc but very hard to find 14x 1.5..
Get the gorilla system lugs on amazon and call it a day..all 5 are locks and look great..I also have the "spinner" gorilla lock on each wheel for added piece of mind...25 series tire rides just fine as long as load rating is 97..no worries
Sitting by your car with a .45 cal is probably the best protection lol..
Anyway, here are some pics and part numbers from Amazon...I got both sets for under $60 shipped on Amazon.
Here is the info link for the Gorilla "System"
http://www.gorilla-auto.com/the-system
Here is the info link for the Gorilla "Guard" (spinning sleeve locks)
http://www.gorilla-auto.com/gorilla-guard-locks
Here are the part numbers for the LS460 along with the link to Amazon
Gorilla System - 71643N
Amazon Link for $40
Gorilla Guard -61641
Amazon link for $13
![](http://www.gorilla-auto.com/graphics2011/12_Page_34.jpg)
![](http://www.gorilla-auto.com/graphics2011/12_Page_36.jpg)
Please be sure to check out this sticky thread for other wheel/tire setups here in the LS460 forum..this is a very informative thread that hopefully more folks contribute to so everyone can benefit even more https://www.clublexus.com/forums/ls4...ls-thread.html
The goal of plus sizing is keeping close to original diameter height as possible.
Stock tire is 235/50/18 has a overall diameter of 27.3"
245/30/22 is 27.8"
*Although this size will work, it is slightly below recommended load index with 93 XL rating, therefore 255/30/22 is better choice with a 95 XL load rating. I ran 265/30/22 up front, but was rubbing on suspension components and fender edge..running 245 now and its just fine. My tire choice does not come in 255/30/22, so I went with 245s.
255/30/22 is 28.0"
265/30/22 is 28.3"
295/25/22 is 27.8"
305/25/22 is 28.0"
I would love to run 255/30 and 305/25 on my next set of tires..a little wider and avoid some of the stretched look at the edge of the wheel. 305/25 is a rare size and I believe only Toyo Proxies have that option, perhaps there are more..not sure.
245/30/22 is 27.8"
255/30/22 is 28.0"
265/30/22 is 28.3"
295/25/22 is 27.8"
305/25/22 is 28.0"
Interesting..I thought our OEM wheels had flat seat lug type and after market wheels required acorn lugs..most after market wheels require a 60 degree tapered acorn lugnut. I'm wondering if your OEM lugs are not properly securing your after market wheel. Do they ever get loose or require frequent retorque-ing to 105 ft lbs?
And with Lumarai Wheels, engineered to fit Lexus vehicles perfectly ........ ya get to use LEXUS factory-standard lug nuts. 1 more thing you don't haveta worry about.
Just annuder important Factoid from yer friend out on the Lake. LOL !
Hey ! Big Wishes to all for a superb week ahead - Mikey Lulejian
