Power folding mirror concerns...
Old 02-26-12, 11:25 PM
lbintab
lbintab's Avatar
Default Power folding mirror concerns...
Hello all...so here are my issues with my drivers side mirror. There's some slight movement of the entire housing forward-back. Maybe a quarter inch...not much to notice but I see it in the image in the mirror. Not sure if anyone else has this problem. It'll shift/move at higher speeds or if I move it with my hand. Also when it folds in the driver window stops it and not by itself. Like it touches the window to stop. The passenger side stops well before it hits the window. I noticed this when I switched the mirrors to close with the window open. It kept on closing in until the corner of the mirror was in the car. I'll try to post picks tomorrow. Anyone know what might cause this? Is there something inside the mirror that tells the motor to stop turning the mirrors in?
Folding mirror Video
Old 02-27-12, 12:34 PM
MikeE12345
MikeE12345's Avatar
Sounds like something isn't right. I checked mine and there is very little play and it stops short of any contact with the window or frame.
Old 02-27-12, 03:49 PM
lbintab
lbintab's Avatar
I updated the first post with a video
Old 02-27-12, 03:59 PM
kitchamp
kitchamp's Avatar
mine have slight play (less than 1/4") in the open position, but no play in the closed position. also, mine don't fold nearly that far, not quite parallel to the door glass. seems like yours are malfunctioning, especially if they only stop because of the glass.
Old 02-27-12, 04:03 PM
cheez80
cheez80's Avatar
mine have play when they're open -- when it's windy out they move back and forth. i guess i'll have it looked at next time i bring the car in
Old 02-27-12, 10:23 PM
Dema
Dema's Avatar
Is powered mirrors standard option?
Old 02-27-12, 10:41 PM
Mikey100
Mikey100's Avatar
Yes. It's all covered in your Owners Manual.
Mikey Lulejian - Lake Oconee, GA
Old 02-28-12, 03:38 AM
CJITTY
CJITTY's Avatar
Your motor is bad and will need replacememt ..same happened to me..replaced under warranty no problem. Dealer says it has to do with some type of stop sensor or something to stop short of touching window.
Old 03-15-24, 10:01 AM
Tratrious
7th Gear
Tratrious's Avatar
Hey, I'm having the same issue with my car. Do you know how much it would've cost you? If done by warranty, I believe you should've got an invoice with it zeroed out because of the warranty.
roli
12-10-17 08:22 AM
SceneAmati
10-02-15 11:15 AM
Phenonix
SC- 1st Gen (1992-2000)
15
11-17-12 01:22 PM
MeehSoFly
11-12-04 11:08 PM
Quick Reply: Power folding mirror concerns...
