LS 460 USB input
Old 02-27-12, 05:33 AM
abbeyrd
abbeyrd's Avatar
Default LS 460 USB input
I am told that the 2011 LS 460 (non- Mark Levinson) has a USB input. Can someone please tell me what format the music on the USB flash drive needs to be for the music to play on this system from the USB flash drive?
WMA, WAV, FLAC, etc.
The person I am trying to help would like to input all his music on this USB flash drive and be able to play it in the LS 460 in the random or shuffle mode. I just don't know what format the music files need to be in or whether or not the LS is able to play music from a USB flash drive.
Thanks.
Old 02-27-12, 08:56 AM
InRBigness
InRBigness's Avatar
my Rx uses either .wav or MP3 format and you can shuffle through individual folders or through all folders by holding down the random button for a few seconds. On the Nav screen you will see somthing like FLD.RAND which means it is pulling from all the folders on the USB stick. Pushing random only picks the songs in the currrent folder you are listening to.
There is a post around here that has a picture of the manual that details the acceptable file structure which is basicly FAT32 and Windows but I cant seem to find it.
Old 02-27-12, 12:27 PM
MikeE12345
MikeE12345's Avatar
I was hoping to use an SD memory card but it didn't work. I used a little USB adaptor that accepts SD cards (the ones I use in our camera) and plugged it into the USB port in the car. I loaded a few MP3 files on the SD card with my computer then tried it in the car. Nothing recognised. I suppose this arrangement doesn't constitute an MP3 player.
Old 02-27-12, 04:19 PM
InRBigness
InRBigness's Avatar
I use a USB stick all the time and it works fine. Have not tried a microSD or SD card but make sure you format it for fat32 only.
Old 02-27-12, 10:21 PM
Dema
Dema's Avatar
Do not expect any exotic formats as flax or Apple lossless. Lexus can't even provide unicode, mp3 and wma it is what you can expect.
Old 02-28-12, 08:22 AM
MikeE12345
MikeE12345's Avatar
InRBigness,
Thanks. I formatted the SD card to FAT32 and it worked! I’m a happy man, much appreciated.
Old 02-29-12, 05:27 AM
abbeyrd
abbeyrd's Avatar
It seems that only MP3 and WMA files can play on this system.
I transferred some WMA music files to a USB stick for my boss. He got it to play but is complaining that the volume is very very low. Is there a reason for this? Any recommendations? (other than turning up the volume).
Old 02-29-12, 06:44 AM
MikeE12345
MikeE12345's Avatar
I've noticed that volume levels are different between FM/Sat/USB/CD but not a large amount. The problem may be related to the source files and, if so, you could use an audio editing program to boast the volume level. I'm not very familiar with this but there are a lot of them on the net for free. Perhaps others can advise.
Old 03-05-12, 07:07 AM
Jlacck
Jlacck's Avatar
I work part time as an audio engineer. The problem is definitely in the source files as mp3's generally have poorer quality especially when compared to CDs or Wav files. What makes a big difference however is the conversation rate that you use (i.e. 96kbps=poor vs 192kbps=better).
All that said, you can level out the volume of your mp3s in an audio editing program. This is what I do whenever I make custom CDs to play in my car or at home. This certainly makes the listening experience better and more consistent when switching between songs or sources.
Hope this helps. :-)
Old 03-06-12, 12:47 AM
admiralali
admiralali's Avatar
I do agree with you. I did the same with my LS 460 L and it works just fine
Old 06-14-16, 02:43 PM
espresso19
espresso19's Avatar
Does the 2008 have a usb or just an aux?
Old 06-15-16, 06:38 AM
R Z
R Z's Avatar
If you find one in your 08 let me know.
Old 06-15-16, 07:34 AM
tofu
tofu's Avatar
Let me know too !!
I can't believe 2008 LS460 does not have USB port ...
Old 06-15-16, 01:22 PM
R Z
R Z's Avatar
Originally Posted by tofu
Let me know too !!
It doesn't. Started with the 2010. I've been contemplating this: http://www.oemautosound.com/p-71-lex...3-isty651.aspx
I had something similar in my LS430 and it worked great.
Old 06-16-16, 09:02 AM
tofu
tofu's Avatar
How hard to install this?
Quick Reply: LS 460 USB input
