extended lug studs for the ls460????
As the thread states I am looking for some extended wheel studs for the ls460 seems like there aren't any for 14mm 1.5 studs that we use there are a ton for 12mm and others but I just want some a little longer to engage my wheel a little better dont want any spacers with the studs pressed in. any hope or am I just out of luck I will even go custom.. If you guys know anywhere chime in..
aftermarket wheels that i got the faces are a little bit on the thick side and i want a little more stud engagement. minimum is 6.5 turns on 14mm studs, i want more similiar to factory. i found a few places to make custom ones, so im just waiting on them.
