Solution to Color matching foglight bulbs to headlights
I did a DIY on HID install. Since you are new on here, let me help you out by posting the link..but next time you should try and use the search function...tons of info on this site at your disposal
Here is my HID DIY https://www.clublexus.com/forums/5883474-post1.html
CJITTY Thnaks for your DIY post, However i don't belive this will work with the newer model Ls's. I attemptd this and the plactic fender liner is all one piece that goes under the car .
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
Whoa really? I haven't noticed that...and you are sure there are no plugs or anything to remove? There has to be some room to manuever around..can you remove the plugs underneath to give more slack?
It can be done , However it is a bigger job then expected . I removerd the two fender wheels screws and three screws underneeth the car holding bottom plastic and a small air diffuser . and a couple of more button clips . I could squezze my hand inside but could not see enough to replace the bulb.I belive all the plastic under the car would need to be removed to get to the bulbs.
It seems that there is no real solution to color matching stock ugly fogs to the OEM 4300k Hid headlights. I did a lot of searching and tried a few different bulbs and by far these are the best. I would say they match 99%.
They are Sylvania ZXE 9006, which you can get for about 50$ in Autozone. I think 50$ is a bit steep considering you can get HIDs for that price, but i hate the look of hids without projector lenses, since they just glare out the whole fog light.
The only time you can see the fogs and headlights look different is when you are looking at them up close from the side, this is because the projector on the headlights makes them appear more blue than they are, while the fogs remain the same.
Overall very happy with them and I dont think there is a better match unless you get projector JDM fogs with HIDs.
Thats the bulbs I used:
![](https://i114.photobucket.com/albums/n276/stas2007/LS460/zxe9006.jpg)
Well all I have for pics are crappy Iphone shots but it actually is better since you can see lots of glare and the color lines from both headlights and fogs: Enjoy![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
Far Away:
![](https://i114.photobucket.com/albums/n276/stas2007/LS460/IMG_1296.jpg)
Closer, notice the 4 lines and how the color is the same![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
![](https://i114.photobucket.com/albums/n276/stas2007/LS460/IMG_1297.jpg)
More close:
![](https://i114.photobucket.com/albums/n276/stas2007/LS460/IMG_1293.jpg)
And up close:
![](https://i114.photobucket.com/albums/n276/stas2007/LS460/IMG_1295.jpg)
Far Away:
More close:
And up close:
