Thinking about buying some wheels...need help with offset!!! HELP!!
IM thinking about buyin these wheels... FORTUNE ALLOY 21" WHEELS...5x120 bolt pattern, 21x9 in front with a 28 offset & 21x10.5 in the rear with a 38 offset....will these wheels fit my 07 LS460....will i need spacers?
![](http://i1153.photobucket.com/albums/p505/Kr0nic17/wheel2.jpg)
the fronts may be a little aggressive offset-wise, but the rears will fit fine. we won't be able to tell if you'll need spacers or not unless you let us know the disk sizes -- offset and width have nothing to do with whether you'll be able to fit them over the brakes or not
our cars have hugeeeeeeeeeeee brakes, which means you'll need wheels with a high (large) disk for big brake clearance. i've read a few stories from guys on this forum having to run spacers because their wheels came off a BMW which don't have such a bulky brake setup.
Have you looked at this information thread sticky to see what setups people are running?
https://www.clublexus.com/forums/sho...d.php?t=604361
The rears should be fine..front may be too aggressive but a test fit is needed
Lower the offset number the further the wheels go outside the fender. Higher offset means it will tuck toward the inside of wheel well. Our cars have an oem 32mm offset I believe. My wheels are 35mm up front and 9" wide and I am close to rubbing the outside edge of fender with 245/30/22 tires and rubbed inside on susp components and just to the inside of the outer fender with 265/30/22 tires. I am lowered about 2" front and 1.5" rear
