Can auto down on rear sunshade be disabled?
As you know, the rear sunshade on the LS automatically goes down when the car is put into reverse. I can see this causing unneccessary wear on the motor, so I would rather disable the auto down portion if that's an option. I suspect it's like the goofy "I agree" button on the nav that finally went away with my update. I would be most appreciative if anyone could let me know if there is a settings anywhere to have the sunshade only go down if I want it to go down.
John
John
Its a safety issue. Lexus cant set it up for you but if you know a bad *** engineer like Henry (Rominl ) he could probably give you more info to see if its feasible
What Luxofreak said! But I admit i had the same concern of constant up and down movement my solution? Tint the back 20% and leave it down all the time except when it is intended to be used (for privacy). Or not tint and just leave it down until you need the shade.
I think if you use the switch near the gear shifter to put the sunshade down it will stay down. Try doing this when the car is in park or while driving. It works in one of those modes.
John
Keeping it down isn't the problem. Once you put it down, it always stays down. I keep all of the shades (side and back windows) closed, so every time I back out of the garage, the shade goes down automatically. Thanks for all the feedback. Just as I assumed, it looks like I'll have to rely upon Lexus' reliability. I have ZERO intention of keeping this car beyond the three years that it is under warranty, so I guess I'll just enjoy it and not worry about it.
John
John
John
John
