I want solutions to some problems and information?
im new in lexues world and i take 2008 ls460l us spec and There are some problems and inquiries..
1- the car speed cut in 210 km/h ... i want open the speed limit how ?
2- i have problem with front park sensor the back sensor is work ok but in screen show me only front isnt work.. i check it by lunch checker and theres some sensor in front not work then,, i check all the sensor with new one for all and conectors .. then i check the wiring and the master conector every thing is ok... i check it with Electric man he tell me the problem maybe inside the ecu Next to the driver under the dashboard.. ???
3-can i change the Weather temperature Next to the radio from f to c .. ?
I want solutions to these problems if you allow
Thank you
hamad
Thank you
hamad
LOL 1st off welcome and I like how you said "single" on your location (even if it's not intended)
1. You have to send your ECU to some one to crack it ( I forgot which company does it), but people say it is not worth it.
2. Was the car in a frontal accident? I test drove an LS that had the same problem...not sure how to fix it though.
3.I would think that the dealer should be able to do it but again not sure...
I'm not sure where you live exactly but if you can definitely take it to a dealer and see what they can do for you
Welcome to the forums.
To remove the limiter you can choose either
(i) Tom's Racing ECM upgrade; or
http://www.tomsracing.co.jp/products....php?mprID=334
(ii) HKS VAC (Velocity Advance Computer) Type S T-801
http://www.rhdjapan.com/hks-vac-velo...es-t-802-66324
Cool, I have a lot of family living over in Kuwait and I visit there often. I'm surprised that the dealership is like that there... I know there are a lot of places that fix foreign cars there and have used parts ( in the al shweak district), but you can also buy parts online too.
you beat me to the punch on that one!!! you might give 750 a run but no way on the s63 or 65
CHUBYBALL
148
02-27-23 11:24 AM
