AWD and aftermarket wheels
Old 03-26-14, 10:32 AM
  #31
CJITTY
CJITTY's Avatar
Originally Posted by JoniNguyen
Then how do staggered wheels work in lamborghinis? The aventador is AWD running 19x9 and 20x12, the rears are also taller (355/25/20 vs 255/30/19). Power distribution is 40/60% to the wheels. The lexus has a torsen lsd with power distribution of 40/60% also.
http://www.greencarcongress.com/2006...etails_on.html
This lsd should be able to accomodate a staggered set up. but who wants to try??? I ran 265/30/22 and 295/30/22 at stock height and the ride was fine. but the fitment of 255/30/22 and 305/25/22 looked better and i can fit the fronts in.
I don't know about the Lambo setups with a nearly 50mm diameter diff front to rear..based on all the research i did across multiple car forums with awd, the concensus was keep it to 1% difference and possibly as much as 3 %. all I wanted to make sure for my 600 is that my overall rolling diameter was as close to the same as possible and avoid the risk..especially being in warranty. Some of the IS guys reported issues with non matched overall diameters on their staggered but who knows what exactly caused the issue. You ran on that setup and seem to have had no impact that you know of and thats great but I wanted to keep overall diameter as close to oem specs with plus sizing and balancing proper load rating along with it..255/30 and 305/25 takes care of that for me and you will enjoy it too..plus to your point..looks much better
lexier
09-29-18 03:41 PM
rodney978
Suspension and Brakes
09-05-17 10:01 AM
aivothom
04-07-17 11:05 AM
Reeladdict
07-08-16 08:57 PM
ryan78
11-28-13 01:08 PM
Quick Reply: AWD and aftermarket wheels
